Blew My Rear!!!!
Old Jul 18, 2006 | 08:38 PM
  #61
yukonjohn's Avatar
yukonjohn
Navigator
Originally Posted by zippin zee
Yucon, at that point I believe I might have to ask them if they would like to own my corvette again. At least when mine was setting it was a parts issue.
Parts aren't the problem, it's GM admitting they have a problem with this rear end. It's their way of punishing anyone who questions their techno baby. Look at the major list of vehicles on the TSB list for this limited slip piece of work, the 07 is already on it! It's not an issue of a bad batch just a bad design and a failure to admit the problem. Limited slip additive what a joke. I wish I had my C5 back.
Old Jul 18, 2006 | 08:48 PM
  #62
StarJack's Avatar
StarJack
There are a few lemon law attorneys that will listen to your situation and assess it for free. A letter on legal letterhead might get them moving.
Old Jul 18, 2006 | 09:15 PM
  #63
CYA-Vett's Avatar
CYA-Vett
Originally Posted by DrivnXcitment
What are your 60' times? Just curious. Also what launching technique and RPM's are you using?
It's the summer, I bracket race only. Launch off of idle, 2.2 60 foot.
I'll launch at 4,500 when it cools down and I go for broke...literally
Old Jul 18, 2006 | 09:17 PM
  #64
Stage7's Avatar
Stage7
same thing happening. I do not see CYA-Vette's response from 7:15 although it shows in the thread listing of the Tech/Performance forum.
Old Jul 18, 2006 | 09:18 PM
  #65
Stage7's Avatar
Stage7
When I press "reply" I can see the missing posts.
Old Jul 18, 2006 | 09:29 PM
  #66
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Update for anyone still interested. It all turned out fine, the rear was replaced with a brand new unit (05 vs 06 due to the 06 bolt pattern being different than the 05's) It works fine now. They accidentally cracked the passenger side running board, but fixed it and repainted the area. These guys have been very nice and very helpful. They don't quite understand everything about vettes, but with my help they are learning. I've had the car in the shop a few more times for the fuel service issue, the nav system issue, and will be taking it in soon for the a-pillar interior material delaminating.
Glad it worked out! For reference, what VIN range are you in... I'm 125xxx so I'm hoping my later build will have the beginning bugs worked out!
Old Jul 18, 2006 | 09:32 PM
  #67
DrivnXcitment's Avatar
DrivnXcitment
I'm 19xxx
Old Jul 18, 2006 | 09:38 PM
  #68
Ranger's Avatar
Ranger
It will help if you go to User CP, then Edit Options, then look for the pull-down shown in the thumbnail below. Then select 100. Problem should then be solved.
Ranger
Old Jul 19, 2006 | 12:38 AM
  #69
LOS ANGELES PI's Avatar
LOS ANGELES PI
I do not have any pictures but I can guarantee my C6 split the case completely in half on a first to second shift. This was on the runflats. The 05 has some issues that were addressed on the 06's. I think it is a sad state of affairs when you can't take one of these cars to the track on street tires without fear of breaking the rearend. I bought my car for recreation and a little track time is part of the package for me. I truly feel short changed after giving this kind of money for a car with these kind of problems.
Bummer. Very sorry for the trouble. Do you think run flats had anything to do wth this? I surely cannot think about why, the most trouble you can have is hooking up too quick under alot of stress, run flats are known not to not give that kind of traction. This is odd to be sure.
Old Jul 19, 2006 | 02:10 AM
  #70
Krause's Avatar
Krause
I know this is a slightly different scenario, but a buddy of mine wrecked his C5 at a NCCC autocross a couple of years ago. Initially Farmer's Insurance denied his claim because their position was that he was racing. He eventually convinced them that the autocross was basically a sanctioned car club's "driver education" event. Why, if someone happens to have been at a drag strip and a GM service tech claims that the car was raced at the time of the rear-end failure, could the owner not claim the same thing?
Old Jul 19, 2006 | 06:51 AM
  #71
Fore58's Avatar
Fore58
[QUOTE=DrivnXcitment]Well for starters let me tell you how. I have an 05 BONE STOCK C6 Z51 6spd. I dropped the clutch at 1100-1200 RPM (that's no joke it was really that low). I just don't understand how this could have happened on street tires (the Goodyear Runflats) that were not heated up.
I thought that you are suppose to slipped the clutch at any RPM when launching. But dumping or dropping the clutch, you're bound to break something on any car with a stick. I doubt that the stock runflats had anything to do with the breakage. Anyway, parts do break. I hope you make out well on the warranty issue.
Old Jul 19, 2006 | 11:55 AM
  #72
jogar80's Avatar
jogar80
yea so umm...would installing a cradle prevent this from happening?...i dont want to suffer the embarrassment
Old Jul 19, 2006 | 11:58 AM
  #73
DrivnXcitment
I wish I knew. I have been wondering the same thing.
Old Jul 19, 2006 | 11:59 AM
  #74
CYA-Vett's Avatar
CYA-Vett
Will it? No
Might it? Yes
Rears have broken with and without the cradle.
Old Jul 19, 2006 | 03:11 PM
  #75
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I firmly believe in the DTE brace. I installed one along with some 555RII's and have made many passes down the strip. On one occasion the car violently wheel hopped for 20-30 feet. I am quite sure that with the combination of the high HP my car has and sticky tires it would have been a disaster without the brace.
Old Jul 19, 2006 | 03:49 PM
  #76
jogar80's Avatar
jogar80
sounds like reason enough to spend the money on it. Cheap insurance. thanks guys
Old Jul 19, 2006 | 03:56 PM
  #77
CYA-Vett's Avatar
CYA-Vett
I've gotten tone of wheel hop, multiple times, multiple passes. Also wheep hopped through a burnout. No brace, no break.
I don't know whether it works or not, but if it is installed incorrectly it will ruin your rear. Cheap insurance? You mean they will pay for a new rear if it breaks while it is installed? It may not cost very much, but it is not insurance.
To Blew My Rear!!!!
Old Jul 20, 2006 | 03:27 PM
  #78
jogar80's Avatar
jogar80
No of course I wouldnt expect them to pay for damage. I just mean it's not alot to spend for any protection it might offer. Seems like a worthwhile option over leaving it as-is or an entirely new unit.
Old Jul 20, 2006 | 08:30 PM
  #79
CBB's Avatar
CBB
Well, if you bust your differential and take it back to the dealer and tell him that:
"I was doing some spirited driving and all of a sudden it broke."
Or better yet, just trailer it, or have it flatbedded to the dealership and tell him simply, "It broke" and don't get specific.....
You have a much better chance of getting it repaired under warranty.
On the other hand, if you have that brace installed and your differential still breaks, you can probably forget about taking it back to the dealer and attempting to have it repaired under warranty.
The minute he sees that cracked differential case along with, and inside of, that brace, he is probably going to refuse it as a warranty claim. He sees that brace and he is going to know that you were probably racing the car when it failed. Or he could even try and argue that the brace itself caused the failure as it is aftermarket equipment which is directly bolted up to the differential.
Old Jul 20, 2006 | 09:47 PM
  #80
Stage7's Avatar
Stage7
