Just for reference, here's how the new LS2 intake looks from the factory. There's certainly room for improvement here. The rough areas and steps are even worse in person. Every port looks like this, and the problems run deep into every runner.
THIS IS WHAT I CLEANED UP BUT OTHER THEN THAT THERE IS NOT MUCH ELSE TO WORK ON
sscamaro: Mind if I ask what Jeramy charged you for the porting of the intake? Was that all you had done or did you have other work done too, at the same time? I am having a completed exhaust system with headers, hi-flo cats and x-pipe installed this week and was wondering if I should have the intake ported too?
thanks...
thanks for the link and did you get the 388hp with the ported intake and tune ?
I had a tune before the porting, but he checked to see if anything changed. He did a dyno pull before the poting and after the porting. The best was as the tune was before.
thanks...
Porting cost $250.00. I had all the other mods done last year. You might as well have the intake ported and a dyno tune while he is doing all the other work. That way you only have to pay for the dyno once.
But I'm thinking $250. for 15 rwhp is a bargain ! In my quest to see just how much rwhp I can make without going into the engine, this would be an extra nice gain ! Almost as nice a gain as the L/T's I just installed. I will be adding a ported intake, and a set of 1.8 ratio rockers to my car soon, and I'm hoping to see 410-415 rwhp. I haven't dynoed the car since the L/T's were installed, but in talking with my tuner, he said on average he see's similar LS2's pick up 30 rwhp. My car baselined at 345 uncorrected, then with a tune made 355 uncorrected. I hope to be back on the dyno to check the numbers before I install the rocker arms and intake, so I can get the before and after numbers. We'll see.......
Steve.
Read replies # 8 & #27 on this thread, that is also my opinion. Is it going to be flow tested after porting? How will you know if a cylinder is running too rich or worse too lean? Good luck.
Just leave it stock, GM designed it to work the way it comes from the plant.
Sorry I just had to
Is this the same GM that designed my PCM program to run lean at idle and low RPM's and rich at anything over 3,500 RPM's.
Had to say it. Just because GM built it that way don't make it 100% perfect by a long shot. Cars are built for the masses not the enthusiast who wants a bit more.
Spin was just joking with that comment. He is a modding enthusiast.
to the modding enthusiasts, i'll definately be attempting to port possibly my TB and Intake Manifold. Then again i've never ported or polished anything so i'll need to learn how. But that's the fun isn't it?
From what I'm reading you guys are removing so little material how much are you really going to gain?. I've looked at my LS2 intake and there's not much you can remove to gain any benefit. Port matching and clean up does very little to improve flow, because It's not port so much that's inadequate, it's the runners and the size of the plenium that limits the flow capacity of the manifold, and you can't do anything to improve it. An LS6 manifold would be better, but it's TB is to small.
You're trying hard to split hairs here, and it's not for a lack of trying to make it better. It's just not going to work very well. I know the FAST 90 manifold is costly, and it's costly to moddify it and the firewall. I would save my money and get one, because to resulting HP and TQ gains are impressive. Before I installed my FAST my car was making 410RWHP/384RWTQ, after it jumped to 425RWHP/405RWTQ. Then adding my ET 215 heads,it jumped again to 461/435. I really believe even though the ET head design is excellent they wouldn't have worked as well without the FAST. If you're looking for long term gains that can be improved upon as you do more additions; I think the FAST is a good investment. I know this is more than .02 cents, but....
Andreas g.
I got 13HP gain at the rear wheels (dyno confirmed) after Jeremy Formato ported my stock intake, that's pretty much what you got out of the FAST for quite alot less money.
How much is a FAST intake for the LS2 anyway? $250 to have the LS2 ported and $XXX.00 to buy the FAST-which is the better choice with just external mods only?
Hmmmmmmmm?
Hmmmmmmmm?
A FAST intake is about $900, it may give you 10 more HP than a ported one. Dollar-for-dollar you are better off with a ported intake, but it's your money. I know a guy that does it, PM me if interested.
I have a ported intake, I couldn't see spending the money on a FAST.
