Secret NAV Option??
Old Jun 21, 2006 | 04:25 AM
888usa's Avatar
888usa
Default Secret NAV Option??
I have been told that on the Factory NAV system there is a way you can have your bluetooth phone work with it as a hands free system as the C6 NAV has the voice activation you can get your phone calls the same way? This system is the same as a Cadillac which can have the bluetooth setup I have not heard of this do any od you guys know if this true I have looked up in the manual it does not say anything are there any secret options I should know?
Old Jun 21, 2006 | 07:05 AM
AFVETTE's Avatar
AFVETTE
This is the first time I/we have heard of this possibility. It would be nice if this feature was "hidden" somewhere and just needed to be "turned on. I know you could add the LTPS to C5 Z06 and by using GM TECH II tool you could turn on this feature that was toggled to "off" as the Z06 didn't have the sensors in the wheels. Once this was discovered I and other C5 Z06 owners added the wheel sensors and turned on this feature and low and behold we could monitor our tire pressures just like the non Z C5's. You could also turn on the auto on headlight system that was turned off.
So it's happened before, but so far this is the first time "hidden" Bluetooth has been mentioned.
Tom
Old Jun 21, 2006 | 07:12 AM
vette-oholic's Avatar
vette-oholic
That would be sweeet, but I highly doubt it exists.
Old Jun 21, 2006 | 07:26 AM
888usa's Avatar
888usa
Well maybe does anyone know of somebody with sat-nav on a cadillac CTS/STS/ if that has the Bluetooth option I think the NAv system is the same the screen may look different but the software is the same?
Maybe you need a Tech 2???
To Secret NAV Option??
