I went on a 3500 mile trip two weeks ago and went to our race shop so I could do some post-trip maintenance on the C6. All was pretty normal, except I noticed my wheels all needed torquing. About 1200 of the trip miles were on very twisty roads (Deal's Gap, etc.) so I think we all should get out the old torque wrench every so often, especially after doing a track event, autocross, or twisty mountain roads.
I went on a 3500 mile trip two weeks ago and went to our race shop so I could do some post-trip maintenance on the C6. All was pretty normal, except I noticed my wheels all needed torquing. About 1200 of the trip miles were on very twisty roads (Deal's Gap, etc.) so I think we all should get out the old torque wrench every so often, especially after doind a track event, autocross, or twisty mountain roads.
When you guys say you "check" in torque on the lugs. Tell me how you do that.
To check mine, I actually
(1) raise the wheels
(2) loosen the lug nuts and
(3) retorque them using a three step progression 35, 70, 100, following a star pattern, so that no two adjacent lugs are tightened sequentially.
Short of doing those steps, what is the procedure for just "checking" the set value?
(3) retorque them
Ranger
Unless you somehow feel that driving the car around is tightening the lug nuts just set your torque wrench to the desired/previous setting and tighten.
'Checking torque' is accomplished with the wheels on the ground and the wrench set to 100 lbs (as an example, since many will argue with the recommended torque). Using whatever tightening pattern you are comfortable with, apply pressure and if the wrench clicks you are good on that stud. If it tightens further and clicks, you've torqued it.
Coincidentally, I had the right front wheel off my 2006 Z06 with 3800 miles this morning, and after torqueing it I went around the car with the wheels on the ground and tightened 2 or 3 nuts on every other wheel a bit. It was the first time I checked them since I got the car April 1st.
So torqueing per the Major's method or on the ground, making sure your wheels are on soundly can't be overemphasized!
Yeah, just have the car on the ground and check the lugs by going to every other one in rotation. Doesn't hurt every so often to back off a lug that clicks quickly and retorque. The more you do this, the better your 'feel' will get.
My lugs were torqued at delivery. And in the 5500 miles since, the fronts have been torqued three times (when removed for cleaning) and the rears sixteen times, when the DRs have gone on and off.
when i put my locking lugs on my new vette the day i picked it up, almost all of the lugs were too loose. not sure why, but ceratainly not a bad idea to have the dealer check before you pick up the car, or if you already have the car, check them
Any time I reinstall a wheel, I retorque the nuts after about 25 miles, and then about every 200 miles until I get two consecutive times when none of the nuts moved at the specified torque. Usually, they move at 25, 200, 400 miles, then stay tight after that.
Of course I also check them before and after any autocross or long trip
BTW, do NOT use any oil or antiseize on the studs/nuts, the torques values are for "dry" threads.
If you use the above method of "apply pressure and if the wrench clicks you are good on that stud", how do you know it's not over-torqued to say 150lbs?
You don't... which is why I back them off if any feel oddly tight. That is just standard procedure for me.
If you are checking wheels that someone else torqued, back them off and retorque to be sure they aren't overtorqued. if you were the last one to torque them, you need only set wrench at 100 lbs and check them.......unless someone can tell me how lugs can get tighter as you drive??
I always am able to get some nuts to tighten more after installing the wheels, even if I just drive around the block. So they need to be checked at least once after installing wheels.
Well in my case I go between track tires and street tires so I do all my own tightening and I'm not using an air tool. I don't think I'm overdoing it.
Here is an explanation of why it's necessary to loosen the lugnut and retorque it.
Originally Posted by glass slipper
...If you have a bolt/nut torqued to an unknown torque, there is no way to determine what it's torqued to. All torque values are taken when the bolt/nut is moving. The dynamic (bolt/nut moving) coefficient of friction is less than the static (bolt/nut stationary) coefficient of friction. So once you stop moving, the amount of torque required to start the bolt/nut moving again can be 50-100% of the amount of torque existing with dry (no lubricant) threads. So say you have a lug nut that is at 70 LB FT, it can take anywhere from 105-140 LB FT to get it moving again. If your torque wrench is set to 100 LB FT and clicks without the bolt/nut moving, the only thing you know is it's torqued to 50 LB FT or more. It may be 150 LB FT, or it could be just 50 LB FT...don't risk it, continue using the procedure you used. When in doubt, loosen and retighten making sure the bolt/nut continues moving in a smooth motion until the torque wrench clicks.
There is a lot misunderstanding about torquing bolts/nuts. Most people think bolts/nuts are torqued to prevent them from loosening. If that was the reason, there are many ways to prevent a bolt/nut from unscrewing. The main reason we torque bolts/nuts is to preload them to prevent fatigue failure of the bolt/stud. If we torque above the max load the bolt/nut will see, no alternating stresses (like bending a paper clip back and forth) will occur thereby eliminating fatigue failure. http://www.tpub.com/air/3-7.htm http://home.jtan.com/~joe/KIAT/kiat_1.htm
If a wheel is removed on any of my cars by someone other than myself, I have always backed off all wheel nuts and then retorked when I got the car home. Like you, I jacked the wheel I was working on to keep it centered on the studs. It seems to me that if I tork the nuts with the full weight of the car on the wheel, it might be tightened off center. I must admit that lately I am getting lazy and have, on occasion, retorked with the wheels on the ground. Must be advancing age related laziness.
I've never, ever done this for any car; yet I've never had a wheel come loose or known of a problem from an improperly torqued wheel. Now that I have changed the C6 wheels to DR's on occasion, I got a torque wrench.
Do you recommend this for all cars? What kind of problem are we eliminating? Realistically. Also, is the 100lb for all cars, or do I need to look it up for my other vehicles?
