Traction Control System
Old Jul 2, 2006 | 08:41 PM
BearCreekC6's Avatar
BearCreekC6
Default Traction Control System
OK......I've read the owners manual, searched the forum, and still don't know the answer...... When would I want to turn off the TCS?
Old Jul 2, 2006 | 09:42 PM
TMyers's Avatar
TMyers
At the track. I never turn the system off on the street.
Old Jul 2, 2006 | 11:52 PM
thomas walters's Avatar
thomas walters
If you are generating significant horsepower, as I am with a Pro Charger and several other mods, you want to turn off the T C before you run your Vette through the gears. Having the T C system shut your car down is not a pleasant experience. It never happened to me until after I finished with my mods. Subsequent to the modifications, I have made the mistake of forgetting to disengage the T C three times and I have been shut down each and every time. Also, when dyno tuning any Vette, regardless of mods, the T C and Active handling should be disengaged. This is accomplised by pushing down on the console button and holding for 10 seconds.
Old Jul 5, 2006 | 06:31 AM
yell03's Avatar
yell03
Here you go:
***1 push of the button -
TC off/AH on
***2 pushes of the button - Competitive driving mode
TC off/AH on, but not as intrusive
***Push button and hold for 10 seconds -
TC off/AH off
TC = Traction control
AH = Active handling
On the street I usually run traction control and AH on, but at the track I go with both TC and AH off.
In warmer summer weather with hotter and stickier streets, you can get away with turning TC off or competitive driving mode.
In the winter, I always leave TC and AH on as the back end likes to kick out with less traction available.
Not to mention, it only costs you about 1/10 in the 1/4 to leave everything on, so for quick light to light blasts, leaving it all on is very consistent.
Howard
Old Jul 5, 2006 | 08:33 AM
Miaugi's Avatar
Miaugi
Originally Posted by yell03
Here you go:
TC off/AH on
TC off/AH off
Howard
Old Jul 5, 2006 | 05:54 PM
BearCreekC6
Thanks to all............
To Traction Control System
