Exhaust tips-not even?
Old Jul 6, 2006 | 02:30 PM
rmd8136's Avatar
rmd8136
Default Exhaust tips-not even?
Not a big deal, but I noticed the stainless steel twin pipes on my C6 Coupe are not evenly spaced, right to left. The passenger side pair stick out about 1/2 inch further than the driver's side pair. In other words, that pair protrudes further out of the muffler. The rear ends of the mufflers are exactly lined up. SO I can only conclude the pipes are actually longer on that side.
If you look from the side (underneath) it is obvious; mufflers line up but pipes don't. I looked at a Z06 in our club and it is the same way.
Are all C6s like this?
Old Jul 6, 2006 | 03:39 PM
JackBurton's Avatar
JackBurton
The left/right spacing is off on mine. The tips are about 1/2" closer to the driver's side than the passenger's side.
Old Jul 6, 2006 | 05:01 PM
redbird2000's Avatar
redbird2000
that would drive me crazy. Isn't there any way to adjust the tips?
Old Jul 6, 2006 | 05:21 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Loosen the clamps at the H pipe and you can move one side farther in/out. Not sure how much you can play with left/right spacing, but there's probably some play where the rubber hangers are bolted to the frame.
Old Jul 6, 2006 | 05:34 PM
AU N EGL's Avatar
AU N EGL
There is an easery way . . .
There they are straight now.
Just kidding what mlongo says will work.
Old Jul 6, 2006 | 05:49 PM
mlongo99's Avatar
mlongo99
Old Jul 6, 2006 | 11:44 PM
97coupechuck's Avatar
97coupechuck
To Exhaust tips-not even?
