Interior lights- HELP
Old Jul 14, 2006 | 12:36 AM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Default Interior lights- HELP
Weird. All of a sudden, the interior lights wont turn off. Even while driving, etc. Its in the garage now and they are still on. Yes, I did reclose doors, reclose hatch and checked to make sure the light switch is off.
I could sure use some advice before my battery drains. Anyone?
Old Jul 14, 2006 | 12:51 AM
knkali's Avatar
knkali
they should automaticaly power down after 20 min. This is a fail safe built into the car. Wait and see. Or disc the battery
Old Jul 14, 2006 | 12:55 AM
LOS ANGELES PI
thanks, i saw this by searching firts, sorry. BTW, do you know which is on/off on the reading lights? Is button in-off or on???? I have hit them so many times now I dont know which is which.
Old Jul 14, 2006 | 12:56 AM
knkali's Avatar
knkali
in is on
Old Jul 14, 2006 | 01:00 AM
LOS ANGELES PI
Originally Posted by knkali
in is on
HUH, ? On the other general, folks say in is off, and out is on,.......
Old Jul 14, 2006 | 12:42 PM
Vette_DD's Avatar
Vette_DD
In is OFF. Sounds like you accidentally hit the switch near your left knee as you were getting into or out of the car. That same button that dims or brightens the dash lights when twisted, is also used to turn on/off the interior lights by pressing it.
Old Jul 15, 2006 | 02:00 PM
VET4LES's Avatar
VET4LES
That's the most common cause of your problem.
Old Jul 15, 2006 | 04:47 PM
Hoonose's Avatar
Hoonose
I can't believe how often this is mentioned.
Have they at least improved on this little option for '07?
Old Jul 15, 2006 | 05:25 PM
shopdog's Avatar
shopdog
I can't believe you guys are hitting that switch with your knees. I'm 6 feet tall, and my knee never comes within 6 inches of that switch. Are you guys with the problem extremely long legged? Are you not using the easy exit feature of the car?
Old Jul 15, 2006 | 06:35 PM
VET4LES's Avatar
VET4LES
I'm 6'1" and my knee doesn't come close to the switch. I have read about the problem many times but that seem's to be the answer.
Old Jul 15, 2006 | 09:35 PM
Firedog's Avatar
Firedog
The short guys have the seat moved up....
Old Jul 15, 2006 | 10:47 PM
jschindler's Avatar
jschindler
Okay guys, I think I'm confused. Is this the 367th, or 368th post from someone this has happened to?
Seriously, this has happened to so many C6 owners that once again, GM should fire someone for such a crummy design flaw.
Old Jul 16, 2006 | 03:14 AM
bocabob's Avatar
bocabob
LOL... Took me like an hour to get this one solved...finally did and felt like a dumb ***... but now I have the knowleged and power over the interior lights. I am a new man.
Old Jul 16, 2006 | 04:17 AM
shopdog's Avatar
shopdog
Ah. So its the short guys. Seat raised and forward. Makes sense now.
Old Jul 16, 2006 | 06:28 AM
timd38's Avatar
timd38
I did it cleaning the inside glass of the windshield with my knee.........
However, my car came with this thing called an "owners manual" and if you look in there, it will tell how to turn the interior lights on and off.
Old Jul 16, 2006 | 07:42 AM
shopdog's Avatar
shopdog
Hmmm, I use my hand (holding a bit of newspaper) to clean the windshield. Never thought of trying to clean it with my knee.
Old Jul 17, 2006 | 05:06 PM
LOS ANGELES PI
Well, it looks as though I am to blame.
I installed my Valentine using the invisicord to attach to power at rear of mirror. When I reseated the pins into the sockets the lights started working correctly. I must have been crossing the current and therefore cauing the map lights to remain on.
To Interior lights- HELP
