Door Opens without Key Fob
Old Aug 3, 2006 | 11:53 PM
lambolarry's Avatar
lambolarry
Default Door Opens without Key Fob
My friend opened my C6 the other day, it's been sitting for 4 days, the key fob was in my house 60 ft away. I had it programmed to lock when leaving. How can I change this? I opened it tonight myself, when I had been away for 3 hours, and no key fob. Is there something the dealer can do? Or do I have to push lock always on the key fob when I walk away ?
Larry
Old Aug 4, 2006 | 08:55 AM
dennis50nj's Avatar
dennis50nj
lock always the pasanger door wont open till you open the drivers
Old Aug 4, 2006 | 09:01 AM
Miaugi's Avatar
Miaugi
Larry
I would first start by going through the "Options" on your car first. Start the car and hit "Options" and take your time to go through all the settings to make sure they are set the way you would like. If there is still something not right, a trip to the dealer will be in order.
Old Aug 4, 2006 | 09:06 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Larry
Did it in fact "beep" when you walked away ("lock on leaving")? Test that again to be sure it's actually locking or go thru the "Options" menu on the DIC to reset. Read thru the Owner's Manual for the various options available.
Old Aug 4, 2006 | 01:09 PM
Vette_DD's Avatar
Vette_DD
There are 3 different options for Passive Door Locking: OFF (default), SILENT, and HORN. If you choose SILENT, I'd also set another option, Flash at Lock.
It's quite likely you've got something programmed incorrectly and the doors are not locking for that reason.
Old Aug 4, 2006 | 02:25 PM
whitesox05's Avatar
whitesox05
Additionally, there are two drivers settings to program and each associated to one FOB, which is numbered on the back of the FOB. If you programmed Driver/FOB 1 to lock on exit that does not mean you programmed Driver/FOB 2. You may have used the "other" one last time you exited the car. I had a similar instance with "easy exit" not engaging but I was using the "other" FOB.
Old Aug 6, 2006 | 10:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Bingo!
To Door Opens without Key Fob
