There was a post by spinmonster whereas he noted the LPE cold air moved the MAF & IAT away from the radiant heat of the radiator & radiator pipe.
Call me crazy but if you continue on that line of thought and construct something to project the radiant heat away from the MAf & IAT maybe the ECM would not pull as much timing.
We need someone to conduct an experiment and see what the result is
base on brett hunter's data logging, this "radiant heat" doesn't seem to be too much of an issue as long as you are moving.
