Sooty tail pipes
Old Sep 20, 2006 | 09:56 PM
aaaaa's Avatar
aaaaa
Default Sooty tail pipes
Help me understand; if these cars are tuned so lean why are my pipes black? I have a DIY CAI.
Old Sep 20, 2006 | 09:58 PM
Miaugi's Avatar
Miaugi
Good question!
Old Sep 20, 2006 | 10:32 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
They are invariably tuned rich (for safety), not lean, from the factory.
Old Sep 21, 2006 | 06:55 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
good question.
did you happen to notice if your pipes were becoming 'sooty' before you built your cai ?
oddly enough, i haven't noticed too many 'pure stock' vettes with 'sooty' pipes. maybe i'm wrong, i just haven't seen it.
i have noticed, and experienced, the exhaust 'tips' becoming blackened after the mod. bug bites.
more air requires more gas, more gas requires more aggressive spark/ timing ,etc.
i've lived with mine for about 2 years now, can't say i don't wish they would stay cleaner but on-the-other-hand, i'd rather it be a little rich than too lean, especially on the top end.
Old Sep 21, 2006 | 07:05 AM
adrnln1's Avatar
adrnln1
My STOCK 06 is rich. I have to clean soot every wash. I will have to have it tuned sooner or later.
Old Sep 21, 2006 | 10:15 AM
haljensen's Avatar
haljensen
The cars are designed to pass emissions tests at specific RPM and load, requirements are around a 14.7:1 A/F ratio. BUT; They are also designed to protect against Warranty damage so at full throttle open loop the A/F ratio can go as rich as 12:1.
Rich = Safer, cooler combustion, lower pressures and temperatures.
Lean = Dangerous, hotter combustion, higher pressures and temperatures.
Old Sep 21, 2006 | 10:28 AM
AFVETTE's Avatar
AFVETTE
For various reasons these cas are tuned "rich" from the factory. A rich mixture helps cool the cats and helps prevent pre-mature detonation. Most "tunes" are removing that fat and getting the AFR's UP to the ideal 12.7 - 13.5 range. My 03 Z had AFR's down to 10.3 after 5200 RPM. Talk about "rich" my exhaust pipes looked like a diesel within 100 miles. A tune would have netted me at least another 15 RWHP.
Tom
Old Sep 21, 2006 | 12:30 PM
catbert's Avatar
catbert
My pipes look like I'm running a diesel.
Old Sep 22, 2006 | 04:30 PM
DIAMOND DAVE's Avatar
DIAMOND DAVE
Thats nothing, before I got a tune, you would think I had a midget under the hood shoveling coal in it.
Old Sep 22, 2006 | 10:20 PM
cmb13's Avatar
cmb13
You mean a little person?
Just kidding, I just saw that on a comedy routine.
Old Sep 23, 2006 | 08:29 PM
Wayne O's Avatar
Wayne O
CF Senior Member
My LPE 403 has the A/F ratio at 12.8/1 .... I clean the inside of my chromed Corsa tips out every couple of days. It doesn't look like a coal mine but hey....it's an internal combustion engine.
Old Sep 24, 2006 | 12:16 AM
DrivnXcitment's Avatar
DrivnXcitment
To Sooty tail pipes
