High beams not working
Old Oct 24, 2006 | 09:51 PM
pharmpod's Avatar
pharmpod
Default High beams not working
Tonight I flashed my high beams and nothing.
Then I tried switching the high beams on, again nothing.
I get the blue signal on the gauge panel.
The head light stays on low beam.
Any idea(s) as to what to check before I make an appointment with the dealer.
Is it something that can be shut off with the tech II?
The reason I ask that is the bcm needed to be replaced.
While I waited for the bcm to arrive, the technician shut off some functions (power top, windshield wipers-all speeds except high, power trunk opener, maybe more). After replacing the bcm, all functions were turned on. Maybe he forgot the high beams.
I have a 2005 convertible.
Thanks, Benny
Old Oct 26, 2006 | 06:15 PM
pharmpod's Avatar
pharmpod
in case anyone was curious, the dealer replaced both high beam bulbs.
Old Oct 26, 2006 | 10:33 PM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Thanks for the update. I don't think you got any earlier responses because your problem seems to have been no one else had experienced.
Old Oct 26, 2006 | 10:35 PM
VET4LES's Avatar
VET4LES
Good news. It's interesting that both bulbs burned out at the same time.
Old Oct 26, 2006 | 11:22 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Seems odd. Glad you got it fixed.
Old Oct 27, 2006 | 08:44 AM
pharmpod's Avatar
pharmpod
I find it odd that both bulbs did not work.
I glanced at the inner wheel liners.
The push pins look fresh, undisturbed.
I am doubting that the bulbs were replaced.
I think it may have been something else,
like turning it on in the bcm.
But then again, anything is possible.
BTW, the car has 600 miles on it.
I will give it a more thorough look over in the morning light.
Thanks to all who listened.
Benny
To High beams not working
