Torque Specs for Caliper Bracket
Old Nov 9, 2006 | 01:22 AM
HeatLtC6's Avatar
HeatLtC6
Default Torque Specs for Caliper Bracket
Does anyone know the torque specs for the caliper bracket bolts. I began the process of painting my calipers using the Dupli-Color paint kit. Instructions advised to remove the brake pads for best results, so I removed the two large bolts to pull the caliper off which BTW were a PIA by hand but no problem for the impact wrench. Also, should I use some lock-tight when I replace them. Thanks Greg
Old Nov 9, 2006 | 12:01 PM
SA HEAT's Avatar
SA HEAT
Brake Caliper Guide Pin Bolt - 23 lb ft
Brake Caliper Inlet Fitting Bolt - 33 lb ft
Front Brake Caliper Mounting Bracket Bolt - 125 lb ft
Rear Brake Caliper Mounting Bracket Bolt - 125 lb ft
Yes....use Locktite
Old Nov 9, 2006 | 02:43 PM
C8-Vette's Avatar
C8-Vette
Blue locktite
To Torque Specs for Caliper Bracket
