Vararam?
Old Nov 20, 2006 | 07:30 PM
C5pilot's Avatar
C5pilot
Originally Posted by ShockerRacing
I keep seeing people saying that it would help to have a lift to install the Vararam. Is this just necessary for swapping the precut shroud? I installed the Vararam without a lift(even though I have one) and can't see any reason that a lift would help.
You only need to lift the front end to remove the shroud (it comes out the bottom). No lift needed if cutting the shroud in place. Just protect the condenser. I just can't say that enough times.
Old Nov 20, 2006 | 08:51 PM
Oli1313's Avatar
Oli1313
St. Jude Donor '09
Went to my locoal mod. shop and they recommended HALLTECH instead of VArARAM. They cited several problems to include sucking of water. Anyway, I was told that HALTECH has been proven to return more HP gains that VArARAM. So what's the deal and you guys' opinion on this matter?
Old Nov 21, 2006 | 12:58 PM
GER42's Avatar
GER42
Based on what I've read and having installed the Vararam I can't see how you would get much more of HP increase on a dyno than any other after market intake with a Vararam since the car needs to moving to "ram" the air. The faster the better. I'm happy with it and now that Pipedreams has made a cover to hide my lousy cut job I'm even happier.
Old Nov 21, 2006 | 01:07 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
wait a sec. does the conversation conclude that the halltech shows gains on the dyno but the vram does not ??
what's up with that ?
why wouldn't the vram show the same type of gain as the open filter design. while the car is on the dyno it will generate the same amount of vacuum with either filter. does the halltech show gains due to a higher cfm filter ? would the vram benefit from the use of 'freer flowing' filter ?
for eaxmple, in order to show any differences between the two i would suspect you would need to baseline the vehicle without the filter and intake ducting. simply the maf, tb, and intake, then add a 'system' and see which 'averaged' better.
Old Nov 21, 2006 | 01:15 PM
GER42's Avatar
GER42
What I meant was the Vararam should show it's biggest effect at speed.
Old Nov 21, 2006 | 03:58 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Living in AZ how much water do you get? Probably not much right. Besides I havn't heard of anyone hydrolocking their C6 with a VR. I have it on mine in NJ and it rained for 5 straight days last week. The car was out everyday in it.
Old Nov 22, 2006 | 12:04 AM
Oli1313's Avatar
Oli1313
St. Jude Donor '09
Well... I came to AZ from Jersey 2 years ago and I also did not know what monsoons were! They are brutal storms that occur without warning. Granted, there is a season for them and you really don't have to drive through them since they only last 30-45 minutes, but there is a possibility of flash floods. Having said all that, I do agree with you... it is not like I am living in WA state. I don't drive the vette if it is raining and if I ever get caught in a monsoon I would just stop and wait it out. I'm still leaning towards the Vararam. I will, as one of the forum members recommended, get a mesh for the front grill. I know it will not stop water, but it will stop it from sucking up all the hugemongus grasshoppers, scorpions, Africanized bees, fire ants, Colorado river poison frogs, snakes, and maybe even a Gila monster into the air vent. These, and the above mentioned monsoons, make AZ a unique place to live. By the way, I have found all these critters (except the Gila) either inside my home, my backyard, or when on a hike 2 minutes from my place.
Old Nov 22, 2006 | 09:03 AM
UTVOL06's Avatar
UTVOL06
I just realized Racemesh grills would be a great solution to the Vararam sucking in road debris or bugs. Thats what I plan to get now...racemesh grill and a vararam. best of both worlds.
Old Nov 22, 2006 | 09:15 AM
cbrf4i1's Avatar
cbrf4i1
Well... I came to AZ from Jersey 2 years ago and I also did not know what monsoons were! They are brutal storms that occur without warning. Granted, there is a season for them and you really don't have to drive through them since they only last 30-45 minutes, but there is a possibility of flash floods. Having said all that, I do agree with you... it is not like I am living in WA state. I don't drive the vette if it is raining and if I ever get caught in a monsoon I would just stop and waited out. I'm still leaning towards the Vararam. I will, as one of the forum members recommended, get a mesh for the front grill. I know it will not stop water, but it will stop it from sucking up all the hugemongus grasshoppers, scorpions, Africanized bees, fire ants, Colorado river poison frogs, snakes, and maybe even a Gila monster into the air vent. These, and the above mentioned monsoons, make AZ a unique place to live. By the way, I have found all these critters (except the Gila) either inside my home, my backyard, or when on a hike 2 minutes from my place.
since you live here in AZ like i do, just so you are aware, vararam scoop blocks about 1/3 of your front grill opening and also doesn't seal off the radiator shroud after your cut it. the point i am making here is, it will be taking air from the radiator by making your front grill opening 1/3 smaller and the air you get from the bottom are not seal off / force toward the radiator instead it is going toward your engine compartment. when we hit 115+ here in the summer, you might have some coolant issue at low speed.
Old Nov 22, 2006 | 09:36 AM
HITMAN99's Avatar
HITMAN99
I've had the Halltech and the Vararam (on 2 different cars) and in my opinion they are pretty comparable IF you have the Halltech fresh air option, or have modified the grille fascia to let in cool air.
The Halltech has a really HUGE filter, and I believe their claims that this results in much less restriction. The Vararam filter is much smaller, and might actually have less surface area than the stock filters.
I have done dyno pulls on my C6, first with the Halltech, and then a few months later with the Vararam and a ported intake. What was interesting was that the manifold vacuum was actually higher with the ported intake and the Vararam. My theory is that the filter is more restrictive when the car is sitting still or moving slowly, but at speed the extra airflow reduces the restriction dramatically. The Halltech is less restrictive at low speeds, but doesn't benefit as much from the extra airflow.
Both systems will help keep the inlet air temps under control, which in my opinion is a major benefit.
Old Nov 22, 2006 | 09:42 AM
BC Bob's Avatar
BC Bob
Ordered both the grille and V/R this Monday.
Old Nov 22, 2006 | 09:54 AM
Zig's Avatar
Zig
since the weather has changed i've been seriously thinking about changing the grill to a 'mesh' style.
imo, the best air will be captured by the vram when the stock grill is replaced with a screen mesh style. the stock grill is composed of diffusors which sit directly across the front of the vram scoop.
it'd be nice if someone had a 'package' that consisted of vram intake, vr spacer, and race mesh grill. something like buy the grill and intake and they throw in the spacer and the precut shroud. that'd work pretty well but then again i've already bought everything except the grill so it wouldn't help me much.
it's been my understanding that HD has the supplies required to roll-your-own but i've also been lead to believe that installing most of the aftermarket units are a real pita. so i don't know which would be worse... but i really need to do something about the leaves. it's fall here..
Old Nov 22, 2006 | 10:36 AM
  #33
Fore58's Avatar
Fore58
Old Nov 22, 2006 | 01:40 PM
  #34
Oli1313's Avatar
Oli1313
St. Jude Donor '09
O.K. ... So I keep reading horror stories about having to cut the shroud. If I am understanding correctly, that problem is solved by the fact that now there is a pre-cut shroud and I'm begining to feel brave about the prospect of doing myself (remember I stated earlier that I am mechanically challenged). Is the pre-cut now standard with the VR or is it extra $$. Also, some state a lift is needed and others don't agree. Just to clarify, is one needed to change the pre-cut shroud and not if you're cutting it or I just don't need one either way?
Me fellow Arizonian, CBRF4i1,what filter do you recommed?
Thanks guys!
Old Nov 22, 2006 | 02:58 PM
  #35
cbrf4i1's Avatar
cbrf4i1
Thanks guys!
vidal, i took that shroud off before, i did have to jack up the front of the car up to help remove shroud. if you are mechanically challenged and you want to do this yourself, this will frustrate you. i have K&n, (pretty much the same as halltech & blackwing) it isn't the most powerful one, since there is no ram air, but i do have the 2 holes cut on the bottom and have air ducts to route ambient air to the filter. i just find this is the best for my comfort due to the high heat here. coolant temp is more important then ram air to me, considering pcm starts to pull timing at ECT 212*. plus with ram air you will have to clean that filter a lot more often, knowing myself i would have clean that filter every 5k miles or so, you know it can get really dusty here.
if l live some cooler place, vararam is an option that i would consider. good luck.
Old Nov 22, 2006 | 04:02 PM
  #36
C5pilot's Avatar
C5pilot
Thanks guys!
I agree with CBRF4i1. If you're mechanically challenged, shroud removal is more difficult than cutting the shroud in place. Not to mention, there is STILL a possibility of damaging the condenser doing the swap.
Just remember, once you have the precut shroud in place, there is no guarantee you still won't have to trim it. That means removing it again or cutting it in place which puts you right back at square one.
No matter what you decide, protect the condenser, and your fenders.
Good luck, and keep asking questions about anything you're not sure of before you begin.
Old Nov 22, 2006 | 06:40 PM
  #37
Oli1313's Avatar
Oli1313
St. Jude Donor '09
Thanks to all you guys! I greatly appreciate all of your advice and know how.
Only one thing... "considering pcm starts to pull timing at ECT 212*"
WHAT IS THIS??? Remember that I am a begginer in learning mode.
To Vararam?
Old Nov 22, 2006 | 06:54 PM
  #38
cbrf4i1's Avatar
cbrf4i1
your computer / pcm pulls timing when ect (engine coolant temp) is above 212 degrees, that means you car will start to lose some power. there is a thread if you care to read it...it has all the charts on timing pull related the ect & iat (intake air temp)
http://forums.corvetteforum.com/show....php?t=1532571
Old Nov 22, 2006 | 07:01 PM
  #39
C64BOB's Avatar
C64BOB
And there's no reason the cut-out could not be sealed around the VR if the template was done correctly. I'm going to buy another shroud and cut the hole to fit. The radiator will work better and it'll keep the dust out of the engine bay.
Old Nov 22, 2006 | 07:14 PM
  #40
cbrf4i1's Avatar
cbrf4i1
when i was looking into vararam a year ago, i called and spoke to one of their tech guy. he told me even with their precut shroud all the cut edges are not seal off. there will always be a gap all the way around, i guess that makes it a little easier for adjustment during the install. since you have the vararam, can you post some pictures of the gap on all sides? thanks
