o2 sensor plugs
Old Nov 22, 2006 | 09:47 PM
excessive81's Avatar
excessive81
Default o2 sensor plugs
i went to napa and a muffler shop and can't find ne one who has anthing that will work. i need to plug the bung on the headers where the rear o2's where
Old Nov 22, 2006 | 11:36 PM
cbrf4i1's Avatar
cbrf4i1
you will not find then in a muffler shop or napa, if i remember correctly from my z28 days, there are all 17mm bolts..i was able to a bolt that would work at the local ace hardware, but the shortest bolt was like 1.25 inch long. MAC exhaust sells off road pipe for the mustang guys, i know they sell the plugs.
Old Nov 23, 2006 | 10:36 AM
haljensen's Avatar
haljensen
Why not use your O2 sensors to plug the holes? You don't have to wire them, use them as plugs.
Old Nov 24, 2006 | 07:57 AM
hayseed51's Avatar
hayseed51
When I installed headers on my 07, there was quite a bit of spatter that had got into one of the bungs. I removed it with an 18MM spark plug chaser. You could probably use a couple of old/cheap spark plugs -maybe even knock the ceramic end off.
To o2 sensor plugs
