Using front wheels for drag radials?
Old Nov 27, 2006 | 09:20 PM
shurite44's Avatar
shurite44
I believe a C5 front is a 58 mm positive offset.
Old Nov 27, 2006 | 10:49 PM
shurite44's Avatar
shurite44
Glenn I think the 265 would fit on the C6 front. I ran a 285 on a 18x9.5 and it fit fine.
Old Nov 28, 2006 | 01:27 AM
LS1LT1's Avatar
LS1LT1
Many are even using a 295 on an 18x9.5 and while maybe not ideal it does work.
Old Nov 28, 2006 | 01:29 AM
LS1LT1's Avatar
LS1LT1
Originally Posted by c6800hp
I bought an extra set of 18" rims and I am running 345 30 18 Drag Radials at 17lbs of pressure on the track.
Wait, they're not stock 18x8.5 inch rims are they?!
Old Nov 28, 2006 | 08:44 AM
c6800hp's Avatar
c6800hp
Yes, they are stock rims!!
Scott
Old Nov 28, 2006 | 10:35 AM
shurite44's Avatar
shurite44
Not a good idea to put a 345 series tire on an 8.5 inch rim. Not sure how they got it on there in the first place.
Old Nov 28, 2006 | 12:41 PM
LS1LT1's Avatar
LS1LT1
Exactly...even for 'limited use' straight line racing only (forget prolonged street driving or cornering which is part of the many benefits of even using DOT legal drag radials in the first place IMO) I wouldn't consider putting a 345 on a 8.5" rim and I'm usually the first one to push it when it comes to tire/wheel combos. Plus the potential sidewall/cupping issues of the tread make that combo quite inefficient for traction.
A 275 or maybe a 295 is about the widest tire I would ever try to squeeze on an 8.5.
Old Nov 28, 2006 | 01:04 PM
shurite44's Avatar
shurite44
Not safe at all. I have a feeling maybe he misunderstood the question or something. Because I really don't think you could get a 345 series low profile tire on that rim. I had 315's put on a 10.5 inch rim once and the manager told me any bigger and they could not have installed it, to stiff.
Also if they are stock fronts I am sure it would rub on the inside. I use stock fronts on my DR's with 295's. There is not a lot of room left for clearance. The 18 inch wheels put the tire closer to the control arms. Actually when it is up on jack stands it just touches on top. When you let the weight off you end up with a little less than an inch.
