Oil Filter Wrench
Old Nov 28, 2006 | 08:26 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Default Oil Filter Wrench
What is the size of a cup-type wrench needed for the PF-48 filter? Is it 75mm, 15 flutes?
Old Nov 28, 2006 | 08:57 PM
Theels12588's Avatar
Theels12588
I can't get to my tools tonight but if someone else doesn't answer it tonight, then I'll go check tomorrow...unless it is urgent
Old Nov 28, 2006 | 10:45 PM
hansenisu's Avatar
hansenisu
St. Jude Donor '10
I stopped using filter wrenches a long time ago. Now I just use a large channel lock pliers to turn'em. Seems to work much better than a filter wrench.
Old Nov 29, 2006 | 12:29 AM
lt1george's Avatar
lt1george
Default filter
Dave, The PF48 (like the PF46,PF52) takes the 15 flutes style. The UPF 44's take the 13 flutes style.>George
Old Nov 29, 2006 | 08:41 AM
davekp78's Avatar
davekp78
Thanks. But the PF 48 is smaller diameter than the PF46.
Old Nov 29, 2006 | 09:10 AM
Wayne88's Avatar
Wayne88
I use the strap type filter wrench.
Never had a problem.
Old Nov 29, 2006 | 09:14 AM
Check 6's Avatar
Check 6
I would agree that there are lots of ways to get the filter off, but if you do not have a filter wrench (fluted cup style) you will not be able to torque the new filter on and there is a specific torque value listed for the C6 LS2 engine filter. There is also a specific torque value for the drain plug.
Old Nov 29, 2006 | 05:30 PM
davekp78's Avatar
davekp78
My point exactly.
Old Nov 29, 2006 | 07:24 PM
glass slipper's Avatar
glass slipper
Me too, best filter wrench I've ever used. It never slips or fails to get a filter off and with the leverage of the 18" long handles, normal removals are a breeze and even the really tough ones (you know, the ones put on by a gorilla) don't make me break a sweat. With its' "one size fits all" universal design, I threw all my different size piece of crap wrenches away (plus I could always find all of them except the one I needed right at that moment) and never looked back. Great minds think alike.
Old Nov 29, 2006 | 07:27 PM
glass slipper
What is the torque spec for the filter? I thought it was 3/4-1 turn tight after the gasket contacted the boss (which can be done by hand). That's what it says on the filter.
Old Nov 30, 2006 | 08:15 AM
davekp78's Avatar
davekp78
The figures I've seen are 22 ft-lbs.
Old Nov 30, 2006 | 08:24 AM
glass slipper
What reference book are you using? Do you have a link? In other words, where have you seen it so the rest of us can refer back to it if we forget the number.
Old Nov 30, 2006 | 02:10 PM
Wayne88's Avatar
Wayne88
Just my .02
Put some oil on the rubber gasket for lubrication, and hand tighten.
I've done this a million times, never had a problem.
Old Nov 30, 2006 | 03:24 PM
Whiterock1's Avatar
Whiterock1
I like the picture of the Rhino in your avatar..
Old Nov 30, 2006 | 03:38 PM
Check 6's Avatar
Check 6
That is a copy of a painting of a one of a kind F4E models that we added two more cannons to. There was only one aircraft configured that way and only 5 pilots that ever flew it. I was the youngest and flew the most missions, mostly in North Viet Nam on armed recce missions and pilot rescues. The painting shows "Chic the Gunfighter" (my callsign) going down the Ashau valley, not a friendly place to fly. I flew at 100-150 feet above the ground and 500 knots .... Do that one day and switch to a normal F4 the next to chase migs .... and they paid me.
As for the torque values right out of the service manual 18 ft lbs for the drain plug and 22 ft lbs for the oil filter
Old Nov 30, 2006 | 04:25 PM
davekp78's Avatar
davekp78
This is from the list of C-6 torque values on this forum provided by David Farmer on 11/13/06.
To Oil Filter Wrench
