Wheel spacers
Old Dec 4, 2006 | 10:07 PM
MtnC-6's Avatar
MtnC-6
Default Wheel spacers
Has anyone used wheel spacers instead of going to wider wheels or ones with a different offset? I saw a 6 liter coupe with Z06 replicas that appeared to have the spacer cast into the hub. I don't believe the wheels were wider because the tires were the standard run flats 245/285 but the tires filled the wheel wells without sticking out. Looked good.
Old Dec 4, 2006 | 10:24 PM
excessive81's Avatar
excessive81
i did it for 6 month until i got wheels and it was fine. there is pics of it on here if you do a search
Old Dec 6, 2006 | 09:34 PM
MtnC-6's Avatar
MtnC-6
Where did you find your spacers?
Old Dec 6, 2006 | 09:50 PM
fastskyline's Avatar
fastskyline
vettebrakes.com
Old Dec 8, 2006 | 08:11 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
dougrippie.com
To Wheel spacers
