Differential Capacity
Old Dec 18, 2006 | 04:42 PM
blown34's Avatar
blown34
Default Differential Capacity
Any know how much lube is needed in a 2006 A6 differential? GM oil and additive or should I use another companies? My front end is starting to plow when turning slowly and I have the magical 15K miles. My C4 made a snapping noise when turning, but this one must have the plates locked up.
Old Dec 18, 2006 | 06:33 PM
UDRIVESLOW's Avatar
UDRIVESLOW
Model Year
Model
Differential Lube
Friction Modifier
2004-2006
Base XLR
1.69 qt (1.6L)
4 oz. (118 ml)
2007
Base XLR
1.95 qt (1.85L)
5 oz. (148 ml)
2006-2007
XLR-V Series
1.95 qt (1.85L)
5 oz. (148 ml)
1999-2005
Corvette ALL
1.69 qt (1.6L)
4 oz. (118 ml)
2006-2007
Base Corvette
1.95 qt (1.85L)
5 oz. (148 ml)
2006-2007
Corvette Z06
2.70 qt (2.55L)
6.4 oz. (190 ml)
UDRIVESLOW
Old Dec 19, 2006 | 02:44 PM
blown34's Avatar
blown34
Thanks, I couldn't find it in the owners manual. I bought a 4 0z. bottle, I hope that will be enough.
Old Dec 19, 2006 | 02:49 PM
C8-Vette's Avatar
C8-Vette
I switched to Royal Purple in the rear. It already contains the Posi-fluid. However, I added the 4 oz. Gm fluid just to be safe. About 10,000 miles and all is well. I guess more is better than less in this situation.
Old Dec 19, 2006 | 05:03 PM
UDRIVESLOW's Avatar
UDRIVESLOW
4 oz. is good for 05 and older...
5 oz for 06 and newer... im guessing you both have a 05...
UDRIVESLOW
Old Dec 19, 2006 | 06:17 PM
C8-Vette's Avatar
C8-Vette
UDRIVESLOW
Yes mine is an 05. Why should GM make the 06 and 07 needing more fluid? Seems GM is trying to solve the rear end clutch problem that some C6 owners are having by adding more fluid. Wonder if they are going to sell the additive in 5 oz containers.
To Differential Capacity
