Cam install Labor Hours?
Old Dec 21, 2006 | 09:06 AM
ALLBlackC6's Avatar
ALLBlackC6
Default Cam install Labor Hours?
When my guy looked, the system called for 20 hours labor to install a cam on my 05 c6. That is with taking the heads off, he said he can do it in half that time w/out taking the heads off. What are you guys doing? Taking the heads off or not? How many hours labor did you guys pay when installing a cam?
thanks
Old Dec 21, 2006 | 09:10 AM
Meegle's Avatar
Meegle
There is no reason to take the heads off for a cam change unless you want them ported or machined.
You can change springs without removing the heads.
Old Dec 21, 2006 | 09:41 AM
Evilways's Avatar
Evilways
Old Dec 21, 2006 | 11:53 AM
andreas g.'s Avatar
andreas g.
turn key install, including cam, springs and new chain should be no more than $1800 and change. I've done two cams at A&A. Also put new wires and plugs in.
Old Dec 21, 2006 | 12:20 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
20 hours? Heck you could just about rebuild the whole engine in that amount of time!
Chas
Old Dec 21, 2006 | 01:57 PM
UDRIVESLOW's Avatar
UDRIVESLOW
2005 Chevrolet Corvette V8-6.0L VIN U
Vehicle Level Engine, Cooling and Exhaust Engine Camshaft Parts Information
Parts Information
Part OEM Part Price
Camshaft
14 - Camshaft 12574519 $275.00 Notes
Labor Skill
Level B Standard
Camshaft
Replace 16.5 Notes
Includes: R&I Engine.
this is from motor alldata this is what a shop should charge for the replacment of the cam..
you leave the heads on..
remove valve covers and remove rocker arms..
remove timing chain and spin the cam..
you will hear all the lifters click..
they are held up by the lifter guides..
then the cam slides out...
good luck
udriveslow
Old Dec 21, 2006 | 02:07 PM
1sweetazzC6's Avatar
1sweetazzC6
Got A quote from a shop here in michigan, labor was 1400.00 alone. Not sure of hourly rate (75-80), which is 17-18 hours labor. Total job with A re-tune ia 2632.00 .
Old Dec 21, 2006 | 03:08 PM
CYA-Vett's Avatar
CYA-Vett
I can swap a cam in 6 hours, these "professionals" better be able to do the same! If you are charged for more than 8, you are being robbed. There are some tuners who will do the job in a day, including the tune.
If they are charging you 20 hours, they don't want to do it. Find a shop with an "installed" price that you are comfortable paying and go for it
Old Dec 21, 2006 | 11:38 PM
brandonf's Avatar
brandonf
4th Gear
FYI
The GM labor time is 15.2hrs for a cam replacement on a C6
And you don't need to remove the heads to do a cam swap
Old Dec 22, 2006 | 12:20 AM
chempowr's Avatar
chempowr
20 hours for a cam change! I should go back into mechanics for a living!
Old Dec 22, 2006 | 07:01 AM
timd38's Avatar
timd38
The last cam swap I did was on my V8 Vega (OK, I am showing my age) that I built, and it didn't take 20 hours......
Old Dec 22, 2006 | 10:52 AM
UDRIVESLOW's Avatar
UDRIVESLOW
he asked what the repair shop labor time was...
not gm waranty time or how long it should take.....
fyi it can be done in under 2 hrs.....
and yes dealer techs make good money..
if you are good....
udriveslow
Old Dec 22, 2006 | 10:55 AM
timd38's Avatar
timd38
if you are good....
udriveslow
A good tech can book far more hours than he/she works, but they earn it!
CYA-Vett's Avatar
CYA-Vett
A cam swap???
No way! not a chance.
Old Dec 22, 2006 | 11:00 AM
UDRIVESLOW's Avatar
UDRIVESLOW
shops charge labor times that are given by a labor time guide...
not by how long it takes to do the job....
I can do things in an hour that take most techs 8..
so should I charge 1? or just slow down? or maybe just start sucking at what I do? please be assured that we charge a fair and honest amount for the services provided...
udriveslow
Old Dec 22, 2006 | 11:24 AM
AP's Avatar
AP
A cam swap???
Old Dec 22, 2006 | 12:03 PM
UDRIVESLOW's Avatar
UDRIVESLOW
come on down and test me.........
just because you cant do it....
i can pull the whole car apart in 2 hrs.....
UDRIVESLOW
To Cam install Labor Hours?
Old Dec 22, 2006 | 12:08 PM
timd38's Avatar
timd38
OK, this is getting ugly.
How is the weather there? It is raining in Detroit.
Old Dec 22, 2006 | 12:14 PM
gtodoug's Avatar
gtodoug
Horsepower sales charged 8 hours which is very very reasonable. It was done basicaly same day.
dougie
Old Dec 22, 2006 | 12:41 PM
UDRIVESLOW's Avatar
UDRIVESLOW
Its 40 Degrees Right Now..
High Of 70 Today... And Clear...\
Not Bad..
Going Snow Boarding This Weekend.....(big Bear)
Udriveslow
