Coolant temp gauge problem
Old Dec 27, 2006 | 06:20 PM
HAVAN123's Avatar
HAVAN123
Default Coolant temp gauge problem
I just went for a drive in my car and was suprise to see in the DIC Hot Engine Turn AC Off. It's 60 degrees outside and the temp gauge reads xxx degrees on the DIC and all the way down on the left on the dash board gauge. The oil temp reads 176 degrees. I hope that its is only a problem with the gauge but the fact that I just had an electric water pump installed worries me. Iwill be taking the car to my tuner. Have anyone else had this problem before?
Old Dec 27, 2006 | 06:33 PM
dennis50nj's Avatar
dennis50nj
it probably has a air lock bubble, let cool completely a couple times and check fluid level.
Old Dec 27, 2006 | 06:35 PM
HAVAN123's Avatar
HAVAN123
I'll do that. Thanks for the suggestion.
Old Dec 27, 2006 | 06:58 PM
cbrf4i1's Avatar
cbrf4i1
make sure your maf harness is plug in. pcm use that data to compare to ECT to know if it is a cold start or not.
Old Dec 28, 2006 | 02:02 AM
LS1LT1's Avatar
LS1LT1
Yeah that might worry me as well, it if isn't functioning properly it could send your coolant temps through the roof.
Old Dec 28, 2006 | 06:28 PM
HAVAN123's Avatar
HAVAN123
Just had my tuner (Horsepower Sales) in Florida check the car. He found the check engine code and reset it. Apparently the electric water pump is flowing so much more water that the computer is setting off a code. on my 30 mile ride home in 80 degree weather,, my coolant temperature never went above 171 degrees @ a crusing speed of 80-85 mph. used Ls2 edit to turn off the code.
Old Dec 28, 2006 | 06:43 PM
Brett Hunter's Avatar
Brett Hunter
If that is the case then I think a higher thermostat temp is in order, not turning off the codes. Do you know what the code was?
Old Dec 28, 2006 | 07:14 PM
HAVAN123's Avatar
HAVAN123
I was thinking the about a new thermostat myself on the way home. I will ask my tuner in the morning. I will also ask about the code. thank you
To Coolant temp gauge problem
