Z51 lowering tips
Old Dec 27, 2006 | 10:32 PM
Atomic-Vette's Avatar
Atomic-Vette
Default Z51 lowering tips
Okay I've done a little searching but haven't really come up with anything concrete. I'd like to lower my Z51 but i've heard some people say they're buying the bolts, and some say that you can lower it with stock bolts. any pics of each or some advice?
Old Dec 27, 2006 | 11:42 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Lower it as far as you can on the stock bolts first. It is real easy. Plus the car will settle some after 5-10K miles. If it is not low enough then buy the lowering bolts and slam it.
Old Dec 28, 2006 | 02:40 AM
shockwaveharry's Avatar
shockwaveharry
Here's a pic of mine lowered on the stock bolts. The rear bolts are cut but the fronts are untouched. I can't see any reason for suspension disassembly and aftermarket bolt replacement when the factory bolts can be cut at will while still installed in the springs. Just my 2 cents.
Last edited by shockwaveharry; Dec 28, 2006 at 02:41 AM. Reason: forgot the pic...
Old Dec 28, 2006 | 01:39 PM
Evilways's Avatar
Evilways
What bolts are you guys speaking of (location) and what was your technique? Did you have to get realigned? Pics?
Old Dec 28, 2006 | 02:22 PM
vettejockey's Avatar
vettejockey
How did you cut the rubber bushing on the stock bolt on the car. I have thought about doing that but have not figured it out yet.
Also what is the distance from the ground to the highest point of the fender opening in the front and rear. Shockwaveharry your car looks great that is what I am shooting for.
Old Dec 28, 2006 | 02:58 PM
Atomic-Vette
yep, I agree that's exactly what I was going for. Do yo have a writeup/pics? how much did you remove from the rear bolts?
Old Dec 28, 2006 | 03:25 PM
AintQik's Avatar
AintQik
When I cut my stock bolts I left a little rubber on the last plate. If you look at it you will know what I mean. Easiest way is with a sawz all.
rj
Old Dec 28, 2006 | 04:33 PM
2008corvette's Avatar
2008corvette
Here's my car, I used WCC bolts so I could remove them and return it to stock height if I ever have to.
To Z51 lowering tips
