Poly Motor Mounts
Jan 17, 2007 | 08:07 AM
Poly Motor Mounts
Does anybody know if there are poly motor mounts available for the C6 or if the C5 poly motor mounts fit on a C6?
I already e-mailed VBP, but they did not respond to my mails.
Bernd
Jan 18, 2007 | 02:56 PM
Jan 18, 2007 | 05:57 PM
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Jan 19, 2007 | 04:27 PM
I just got a response from Energy Suspension and from Prothane. Both do not make poly motor mounts for the C6.
VBP makes poly mounts for the C5. Does anybody know if the C6 mounts are the same as C5 mounts?
Bernd
Jan 20, 2007 | 08:44 AM
You might check with a dealer parts department and see if they are the same part number. Or they might just have the answer if the two interchange.
Jan 20, 2007 | 05:04 PM
Thanks Eurorod. I am going to check that next week.
But if the part numbers from C5 and C6 are not the same, I still do not know what the difference is. I live in Germany and since the Corvette is very rare rare over here, I will not get any reliable info from my local dealership.
Bernd
Jan 22, 2007 | 04:08 PM
Update:
The C5 and C6 motor mounts have different part numbers (thanks Jason!).
On my C6 mount are four! part numbers:
10284134 (1997-2004 C5 mount)
10438289 orange
15254700 green (2005 C6 mount)
92084910 white
I measured the mounts from the C6. They are 70mm height, 112mm diameter and the threads are 12mm diameter and 50mm long.
Does anyone have the dimensions of the C5 motor mounts?
Bernd
Jan 22, 2007 | 07:06 PM
Cruise-In VII Veteran
Quote:
Originally Posted by
Bernd
Update:
10438289 orange
92084910 white
Bernd
I have a set on the shelf at the shop, I can get some pics tuesday
Jan 24, 2007 | 02:09 AM
Thanks.
Could you take some measurements and post them?
Bernd
