Question on Torque>><<<????????????
Old Jan 29, 2007 | 01:05 AM
NORTY's Avatar
NORTY
Originally Posted by glass slipper
A gallon of gas has a certain amount of energy.
Yes,1 gallon of gasoline (perfectly atomicized) is equal to 14 sticks of trinitrotoluene.
Old Jan 29, 2007 | 03:18 AM
shopdog's Avatar
shopdog
Torque is the product of force acting over a distance. In the English system it is expressed in units of foot pounds. In physics, this is called work. Power is the rate of doing work, ie foot pounds per second. In the English system, one horsepower is 550 foot pounds per second. Torque has no time component, power does. Acceleration also has a time component, feet per second per second. So acceleration is a function of available power.
Example, a 550 pound wagon is pulled one foot up a ramp. This requires 550 foot pounds of work. 549 foot pounds won't do it. Wrap the pull rope around a 1 foot radius cylinder, and 550 foot pounds of torque will exist. Doesn't matter if it takes an hour, a day, a month, etc. But now lets hook that wagon to a horse and whip him. He'll pull the wagon up that ramp in one second, exerting 1 horsepower to do so. So power is the relevant number to know if you want to figure out how fast something can be done. Torque is the number you need to know to determine if you can do the work required.
Old Jan 29, 2007 | 08:26 AM
AU N EGL's Avatar
AU N EGL
AU N EGL gave the best link to understand the difference between torque and HP, understand that link and the rest is a piece of cake.
That is easy for you to say.
Old Jan 29, 2007 | 09:38 AM
HITMAN99's Avatar
HITMAN99
Here we go again!
Old Feb 2, 2007 | 03:33 AM
2006c6keller's Avatar
2006c6keller
Originally Posted by DSOM Z51
Power losses through the driveline result in numbers lower than the 400/400. 400bhp/400ft lbs of torque generated at the crank won't end up being the same amount after the energy expended by turning all the gearing and such in the transmission, the differential and then finally the wheels.
I hate this "rule" but it is said that driveline losses for manuals amount to 15% and for automatics 20%. Thus a bone stock manual C6 should dyno with 340 RWHP or thereabouts.
The factory likes to "spice up" the numbers, don't believe the brochures, a selling tool.
Old Feb 2, 2007 | 08:31 AM
LloydP's Avatar
LloydP
Default More on HP vs torque.
Originally Posted by BlakShark
So is it RWHP that you want to increase in order to gain power or is it the TORQUE?
Different people teach this different ways. In engineering classes, they say to ignore torque. HP is the only thing that gets work done. TQ is just a measurement used in calculating torque.
That said, an engine that makes lots of HP down at low RPMs gives a very satisfying kick in the back when you punch it in ordinary traffic situations.
So the vett can accelerate nicely in 6th gear at 60mph (it makes a lot of HP down low). In contrast, a Mitsubishi Evo might be able to hang with a vett in a 1/4 mile, but you punch it in 5th at 60 mph and you will wait a long time to accelerate (it doesn't make much HP down low) . You have to keep the engine on the boil to get any work done.
Hope this is useful. Lloyd
Old Feb 2, 2007 | 10:45 AM
GizmoZ's Avatar
GizmoZ
Originally Posted by johnodrake
How did you determine the Flywheel HP?
I forget what his numbers were, but I'll take my old GTO for example. It put down 344 hp to the rear wheels. I assumed a 15% drivetrain loss, ballpark. Take 344 / .85 and you get ~405hp at the crank.
With a 16.5% drivetrain loss, you would take your RWHP number and divide it by .835.
I think.
Old Feb 2, 2007 | 12:04 PM
johnodrake's Avatar
johnodrake
Moderator
I think.
I get the math. The ~15% is an assumed constant. Since you said that you had a drive line loss of 16.5% that indicated to me that you had a known Crank HP and a known RW HP and thus determined the actual DL loss for your car. What I wanted to know was how you got the actual crank HP to make this calculation - a engine dyno, for example? Thanks, JD
Old Feb 2, 2007 | 02:33 PM
GizmoZ's Avatar
GizmoZ
I'm not that guy
Old Feb 2, 2007 | 04:52 PM
JD21029's Avatar
JD21029
. In short, you can make whatever amount of torque you want with gears, but if you have 505 HP, you'll always have 505 HP...no more and no less (excludes mods...just had to add that disclaimer ). [.
This is the problem with every torque/hp debate I've ever read. People don't compare apples to apples. Yes, gearing has its effect. But the discussion is on the hp and torque of the powerplant. To para phrase a famous saying, give me a long enough lever and I can move the world, but the lever doesn't make me stronger; it just gives a mechanical advantage. Lets not confuse the discussion by bringing in extraneous factors.
As for the calculator and hp being everything, practical experience says otherwise. My CLK55 AMG had less hp, but more low end torque than my C6, and subsequently it got consistently better 60 ft times, and 1/4 mile times.
Old Feb 2, 2007 | 05:16 PM
C8-Vette's Avatar
C8-Vette
Here we go again.....
The more HP you have the quicker you get to the wall
The more torque you have the more of the wall you take with you...
