Do I need a torque converter??
I dropped my C6 (Auto) off last week at a local shop here in Utah, to have the following work done:
Procharger D1 SC with twin intercoolers
Stage 3 ported heads
Stage 1 cam, hardened push rods
Bassani Long tube headers with highflow cats
Torque converter
The Procharger hasn't arrived yet, so I had them start on all of the other stuff. I'm out of state right now, on business, and called the shop up today to see how things were progressing. They stated that everything should be done tommorow with the exception of the Procharger, as it has yet to arrive.
They also stated that they did not install a new torque converter (as originally planned), because the location is too far back in the tranny and would take much more labor than I was originally quoted to perform. They then stated that they would discount, what they were going to charge me for this item.
The shop also indicated that they had consulted with several people and determined that the C6 comes with, "a pretty good torque converter" and that I shouldnt have any problems with it in the future, thus there isnt any need to change it.
So here is my question... I'm not a mechanic and don't know a damn thing about torque converters. Are these guys screwing me around or is it pretty fair advice on their part???
Thanks in advance
In general, any cam worth installing is going to have some negative effect on low-end torque. If you have an A4, then I would say that you could benefit from a mild torque converter. A common situation that occurs with the 4 speed autos is that you will be driving in traffic and have a need to accelerate rapidly in 2nd gear. What often happens is that you will find yourself above the kick-down point for the tranny and above the lock-up rpm for the tc, but below the power band of the engine. As a result, you end up doing a slow, excruciating acceleration up from the bottom of 2nd. With a higher stall converter, you just put your foot into it, the rpms jump into your power band, and away you go. I don't know first hand, but suspect it would not be as much of an issue with an A6.
I like the Precision Industries Vigilante converters.
This is all assuming that you have a 2005 of course.
As far as the comment about the shop.. I didnt really have a choice out here in the boonies. This shop specializes in mustangs and doesn't do too many vettes. However, they are a reputable shop out here and do a lot of performance mods for the Ford dealerships out here and always have a waiting list.
Hey, one question how many teeth does the shop mgr have?
edit Oh well that explains things then. I'd say do the verter. Just wait till you find someone to help you or a shop that can do it. You will enjoy the snap.
I can't imagine utilizing a shop/tuner that actually quoted for a torque converter install without even knowing that no one officially makes converters for that particular vehicle yet.
They might be excellent at tuning Fords but exactly what experience do they have with GM and C5/C6 tuning, not just the installs but the actual PCM/TCM dyno tuning of said vehicles?
Okay, screw it.. when these guys are done with the work, I'll go visit my mom in southern California and have a vette shop look at it. maybe they can figure out where the torque converter is and properly tune the car. Any suggestions of where I can take it? My mom lives in some place called Victorville, it's about an hour from Los Angeles.
