tuning question...
Old Mar 8, 2007 | 06:48 PM
schizcat's Avatar
schizcat
Default tuning question...
Is a professional tune worth the extra $$$ if it wont really be used? i am just going to do exhaust, intake and maybe t stat (still not sure on this one) and was just planning on using a predator handheld. i wont be doing any racing, just cruising. also, does anyone know if there is a way that i can run a custom tune from my laptop?
Old Mar 8, 2007 | 07:08 PM
paulee's Avatar
paulee
yes, some shop will tune using predator software, call the manuafacture, they have a list of tuner / shop in your area that can tune for you using your software, or you could just use the tune from predator.
Old Mar 8, 2007 | 08:40 PM
LS1LT1's Avatar
LS1LT1
Yes
Old Mar 9, 2007 | 12:19 AM
Max@Cartek's Avatar
Max@Cartek
Originally Posted by LS1LT1
Yes
Old Mar 9, 2007 | 04:54 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Mar 9, 2007 | 07:09 PM
kmthor00's Avatar
kmthor00
you'll pick up 15 hp at the wheels with a tune
Old Mar 9, 2007 | 07:48 PM
C6Brian's Avatar
C6Brian
15 at the wheels with JUST a tune? I have a 500 mile old C6 M6 and am going to get a 93 octane tune and have the tq managment turned off, you think its worth the money. Also, if I decide to add a K&N airfilter not the intake should I do it before I get the tune?
Old Mar 10, 2007 | 07:45 AM
Max@Cartek's Avatar
Max@Cartek
For the money, you gain roughly 15rwhp (some gain more and some gain less), but the real gain comes from the reduction of TM. On the dyno the TM will not show. It will dyno the same numbers with or with out TM, but you will show a .3 to .5 gain in quarter mile ET. It's very much worth it.
If you can get the filter before the tune then I would put it in there.
Old Mar 10, 2007 | 08:34 PM
C6Brian's Avatar
C6Brian
Thanks max, looks liek I'll be getting the tune soon then.
Old Mar 10, 2007 | 09:03 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Yes the tune is worth every penny.
I logged a stock C6 Z06 yesterday at the drag strip. IAT was 150 in the staging lanes, got down to 104 at 80 mph and stayed there. Factory tune was pulling 10 degrees of timing at 150 and 6 degrees at 104. It was 84 degrees out.
A C6 is worse because it has no cold air intake like the Z06 does. By the way my Vararam was at 93 in the staging lanes and got down to 84 by 100 mph.
Changing that table alone to be less aggressive makes a huge difference in the way the car feels and runs. Huge.
Here's the table on how much timing is pulled at IAT's starting at 86 degrees. This is a Z06 table but C6 is about the same.
Old Mar 11, 2007 | 04:53 PM
kelp's Avatar
kelp
Good data. However the gray-steel sleeve inserts are particularly vulnerable to the shockwave fronts of detonation. I admit GM is too conservative here. I am sure you have dataloged to see where you are pulling timing, having HP Tuners. Rather convenient!
Old Mar 11, 2007 | 07:52 PM
schizcat's Avatar
schizcat
Thanks for the info guys, i found someone here in SD to help me with the tune. One other quickie, is there a way for me to hook up my laptop to the car to do my own tune? i am adding exhaust in a couple of weeks and may not add other things (intake, 160 stat, etc) until the end of summer. I didnt want to get the tune done with just the exhaust if i am going to do other mods later down the road.
Old Mar 11, 2007 | 11:42 PM
kelp's Avatar
kelp
You can always get HP Tuners and a mail-order tune for $100. I use my laptop. Then you can datalog and see what your car is doing. A tuner can't do that under any condition you want. I doubt if just exhaust, not headers will make much difference, as LTFTs will compensate. Now, intake will change things. (!) But basically - won't interfere with a tune. And you can reset your fans to your new T-stat at your leisure.
(WARNING - TUNING CAN BE ADDICTIVE)
Old Mar 12, 2007 | 12:54 AM
C6 Mayhem's Avatar
C6 Mayhem
Got my stock C6 tuned at A&A a month ago. Picked up 17HP and 20TQ, with no other changes. Runs soooo much better.
To tuning question...
