I am really disappointed
You have great under the curve area. i.e. a great flat torque curve.
High HP are for bench and bar races only, I will take a FLAT big area under the curve any time.
HP sells mods and cars, Torque wins races.
That way I can make sure my car is performing as good as it should.
Best regards and good luck,
Luis
Mods to date are: 160 stat, Magnaflow catback, Vararam w/ spacer, Ported throttle body and LG long tubes.
Took the car in today for a tune and dyno on a DynoJet.
Base line with all the mods was 342 RWHP.
After the tune we got a best of 355 RWHP and 346 RWTQ.
Dyno run in 4th gear.
Using a 15% drivetrain loss, the FWHP only comes up to 408.
12.8 AFR.
Ambient temp was 57 degrees. Low humidity.
I'm disappointed in these numbers. Seem kinda low. I was looking forward to 370+. I am, however, pleased with SOTP dyno. Seems much more responsive. 1-3rd gears feel much more powerful.
Were my expectations too high? Are the numbers in line?
Opinions welcome.
This first picture shows the gains across the rpm range. Remember I only have the Vararam and a tune.
This second picture show the A/F from the baseline to the final tune. If you notice the A/F is not a flat line. Each engines is a little different and Doug at LAPD worked out the A/F where I got the best gains. There is still a bit more that can be had as we ran out of time.
If you notice that even with headers you are only at best getting about 10 more than me. I know you feel you are close but find someone who can tune that puppy. You should be 20 more than myself.
Hopefully I will be adding Headers to mine sometime in the next month or so and I'll head to the dyno shop and check it with the current tune. Unless I can talk Doug to coming up to Seattle to visit family and tune my car I have no idea when I will be able to adjust the tune for the headers.
Luis
On a stock internal (bolt ons only) C6 the injectors should be more than adequate to handle that and as long as one is using a quality/name brand premium fuel a knowledgable tuner would know how to compensate for the potential differences IMO.
100%
Let me know if you do find other options (besides buying Torco all the time ;-) )
Regards,
Luis
http://i115.photobucket.com/albums/n...eDynoSheet.jpg[/QUOTE]
Talked to my tuner via email today. Maybe got some questions answered. Thoughts anyone?
Here's his response with my initial inquiry on top:
Alvin,
I've talked to several Corvette owners about my Dyno on Monday. Everybody is in agreement that my numbers are 30-40 HP and TQ low.
The 342HP we came up with on the initial run are total stock numbers with other cars and with headers and throttle body they are getting 360. With the tune the numbers should be 370-380.
Do you think the DynoJet is out of calibration? Or is it with my car? Or did you leave some HP on the table? My initial reacton is that the car is much stronger, however.
Enjoyed meeting you.
________________________________________ ________________________________________ ________________________________________ _________________
Hey Bob,
Honestly your results weren't terrible to me, but the definitely where not strong. I'm basing that on the GTO's we have done here with the LS2 engine. There are a couple issues that can be to blame.
1. Car not broken in yet. 1700 miles
2. Dyno not broken in yet. The dyno has only been in operation for 2 weeks now and the shop and I have been talking about how it may still be a bit tight. My personal Z06 was a little low on power and I did a LS1 today that was also a bit low on power there.
3. The way they are tying down the cars. They ratchet the cars pretty tightly which doesn't allow for the car to center up on the first chance it gets to roll. The other dyno we use the guys leave the cars a bit loose so the car straightens.. then we stop the car and tighten it down good and tight. IF the car is off by a degree or two you can imagine how it would affect numbers.
If you would like I'd be glad to put yours on the other dyno we use. It has been my experience that the other dyno is a bit optimistic and the one you used is a bit pessimistic. I will be tuning at the other dyno tomorrow. If you'd like I can get you on say at 3:30. I will not charge you for doing this however you will need to pay the dyno operator for his time. I wish the dyno was mine so I could give away the time for free in cases like this. I'll also double check the tune while we are in there just in case we need to tweak something however I was very meticulous doing the tune and it should be spot on. Remember how I did 2 back to back pulls just to double check to make sure the car would stay right.
I will say that honestly I could have probally gotten an extra 3 rwhp in the tune but it has been my experience to set the cars up a touch fat (12.8) so that they lean out and run best on the street. I guess you can say the tune is agressive but safe and with the street in mind.
Let me know about tomarrow. I have no problem putting hte car back up on the dyno.
Thank you,
Alvin
I am the one that tuned this car. My name is Alvin (search for my name on this forum, really popular especially with C4 guys) and I've been working for PCMforless for almost 7 years now. I've done plenty of LS1, LS2, and even showed Bob a few LS7's I've done. Admittedly I have not had a LS2 vette come by but I have done a boatload of GTO's, TBSS's etc. The only C6's I've done have been all Z06's. In fact I overlayed Bob's graphs with about 10 other LS2 equipped cars just to show him how his was comparing to the others I've done. You can check my website www.pcmforless.com to check my credentials. I also have tuned one of (if not the) countries fastest NA bolt-on GTO.
This dyno was done on a Dynojet at a shop I just started doing sublet work on. It became operational about 1.5 weeks ago. So far there have been less than probally 30 cars on it.
Earlier in the week I did my personal C5 Z06 on this same dyno and it too was down a bit of power. Today we did a LS1 with GM's ASA cam and it was also down a bit of power.
I believe this dyno has some breaking in to do. I also believe the shop is tying the cars down a bit too tight before we center the car by rolling them first on the dyno. I am also thinking that this dyno needs to be ventilated a little more properly as it is not hot but the exhaust is against a wall.
I've offered Bob a chance to come down and pull his car on the dyno I normally work on tomorrow. It is also a Dynojet 224 however my personal Z06 dynos quite a bit better on it than the one we used Monday for Bob's.
I personally wouldn't beat yourself up on dyno numbers. My own Z06 doesn't put down a great number but it definitely out runs the hell out of some higher dynoing cars at the track. A dyno is a tuning tool and I'm mostly concerned with as a tuner that the AFR is set and flat to something safe and appropriate for the application and ignition timing has been experimented with so that we know we are at a point that makes the most power with each particular car safely. Ultimately I'm concerned with making the car go as fast as possible on the street or strip.
Also, I'm a fair guy. If Bob isn't confortable or happy with the service I provided I will be glad to return the car to stock and issue a refund.
Alvin
704-307-4227
PCMforless
Alvin
704-307-4227
PCMforless
always more to almost every story. good post, Alvin. And I agree...WAY TOO MUCH emphasis on dyno numbers. How does it run on the street? Can't tell you how many times I've seen "dogs" on a dyno roller simply rip the street/strip up in the real world. The road load factor is hard to duplicate. Keep it safe in the tune, and then have fun on the road!
If you remeber I said that I had my personal car on this new dyno last Monday. Well, last night I put my car on the dyno that I have been using for around 4 years now in the Charlotte area. BAM! 10 more peak hp, 12-14 more in some spots. Let me go ahead and note that I've worked on dynojets all across the country. I have never seen a variation more than say 3-5 hp.
I've got a Z06 to do monday in the AM and then head back over to the shop with the new dyno to handle a fast system on a mustang. Before the Mustang goes up the shop owner wants to put my car back on the dyno (3rd time this 2 weeks) and see if it backs up what it did on the 5th.
Honestly I think one is a half full type of dyno and the other is a half empty. Regardless I think biggest thing people should look for is the before after. IS the AFR good? Did the car pick up power? Was a few different timing tried? If so you are good to go. The actual number is relatively meaningless.
I was stoked
