I currently have a G5X-3 cam, but would like to switch to a
226/234 .598 .599 117lsa What would be the power difference
between the two and would my tune for the G5X-3 be close enough that i'd be able to drive it untill/and or go for a dyno tune? Current setup 441rw/404tq on an '05 A4 with AFR 225's and LG longtubes(LS2 Edit)
Goals are #1 make it a better setup for F.I. #2 the side effect is less lope,better manners. It may not be the cam of choice for TT, but an APS system is not designed for the F55 cars.(have to relocate sensor linkage). So,a Maggie(probably) or a centri(not convinced yet) In the meantime i'll enjoy a smoother idle.
OK, understood. This is probably a better choice for the Maggie as compared to a centifugal blower. The Maggie will tame down the lope at idle. It will still sound nasty, but will idle at a lower RPM, and your throttle response will not suffer. The reason is that reversion is reduced. Reversion is when exhaust gasses contaminate the intake charge during the overap period, when both valves are open at the same time. WIth the Maggie, even at idle the intake charge enters the combustion chamber under pressure, so the exhaust gases are kept out.
The wider LSA reduces overlap, so it also has a beneficial effect on idle. However, I still think that the 117 LSA is more than you need for the Maggie. A 114 would do just fine, does not require a custom grind, and you will still have a nice idle and good street manners.
This same cam on a centrifugal blower would not have as great throttle response or low-RPM TQ. The peak HP would be much higher than the Maggie though. The Maggie will only flow a limited amount of air due to the small size (displacement) of the blower case.
My G5X1 is similiar to what you want...spoke to Anthony at LGM and he suggested this was a very well behaved street cam w/ noticeable lope.
I originally wanted to go bigger, but the practical side of me won out.
(G5X1 228/232 .588/.574 LSA 112)
I am quite happy with it.
Dynoed @ 410 RWHP and 398 RWTQ when car was still running kinda rough...wanna re dyno to see #'s since its running alot better now.
The tune will be fine but why bother swapping the cam?? If you are doing FI, either rebuild the bottom end or bag the whole idea. I can't see why people do this. You can run only minimal boost on the stock bottom end. You are leaving tons of HP on the table. Do it right or don't do it at all.
You can easily run all the boost that a Maggie is capable of producing w/ the stock bottom end. All the power will be made below the existing redline.
If you go with a centrifugal blower or a turbo at high boost, say over 15 psi, that's another story.
Maggies only run minimal boost. No way will a stock bottom end hold up with 15 psi. 8-10 at the most from what I've seen.
I have a 20 year old car that handles 28 psi, or 800HP with a stock bottom end. Difference being, tha tit was biult for boost, the Vette is not.
If you are going to run boost, run boost. 8 pounds, thats cute
The Maggie has an internal bypass valve that makes the engine act just like a NA engine at idle/low load. http://www.magnusonproducts.com/mp112.htm
Therefore, it won't tame the lope at idle at all nor will it idle at a lower RPM or reduce reversion. The intake charge enters the cylinder at idle under vacuum just like a NA engine with nothing preventing exhaust gases from reversing flow and diluting the incoming charge.
Anything that reduces overlap on a FI engine is beneficial as it prevents the intake charge from going out the exhaust during the time both valves are open when under boost. The wider LSA will achieve this objective.
You can say that about any cam when comparing the centrifugal vs Maggie. The centrifugal increases boost exponentially with RPM allowing much more boost at higher RPMs (and higher peak HP) but very little boost at lower RPMs making throttle response/low RPM torque suffer. The Maggie's boost curve is more linear meaning more boost at low RPM and better throttle response/low RPM torque. Since its' high RPM boost is limited by the amount of boost it can run at low RPM, peak HP will be much lower than a centrifugal.
