Calling all LS2 Experts
Old Mar 25, 2007 | 10:18 PM
  #121
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by vett2go
Gee, what does CNC ported Mean???
From http://www.gmperformanceparts.com/Pa...input=12564825
For those that have the 799 head and the rumor of GM dumping out these old Ls6 head, you may just be the lucky ones. The old ls6
Cylinder Head - Cnc Mach Showroom Stock Version Of 2002 LS6 Head
CNC-ported aluminum racing head
2.00" Hollow stem intake, and 1.55" sodium filled exhaust valves
.570" max valve lift
250 cc CNC'd "Cathedral port" intake ports
85 cc CNC'd D-shaped exhaust ports
61.9 cc CNC'd combustion chambers
Bare head p/n 12564825
The super good hollow valves.... small combustion chamber.
WOW
My buddy has the GMperformance CnC heads on his car. I have a call into him to check on his car and I'll report back what #'s he has.
Old Mar 26, 2007 | 10:39 AM
  #122
2kvetmy's Avatar
2kvetmy
2006 vette 4/06 manf w/ 243(w/ noisy rear clutch packs)
2007 avanlanche 9/06 manf 2/ 243
maybe 799 are the more desirable?
Old Mar 26, 2007 | 11:00 AM
  #123
Joe_G's Avatar
Joe_G
St. Jude Donor '08
He called back. He's got 243's. These were purchased from GM Performance a couple of years ago when GM CnC Ls6 heads were pretty hot, before AFR's were so popular.
Old Mar 27, 2007 | 11:28 AM
  #124
JiminFL's Avatar
JiminFL
Originally Posted by Evilways
I meant the oddity of both the 243 and 799 together, sorry, maybe I wasn't clear....I know the number should swap ends on the same head. Has Bob checked the drivers side head? Is it 799 as well??
I have one of the ultra-rare and priceless hybrids. The 799 on the passenger side is stamped at the firewall end, and the 243 on the driver's side is stamped on the firewall end as well, with nothing stamped in the same location on the forward end of either.
Jim
Old Apr 5, 2007 | 12:15 AM
  #125
User 81424's Avatar
User 81424
http://forums.corvetteforum.com/show...post1559680674
243 vs. 799 heads talked to GM research tonight.
I talked to Bob (Gohard777) and Mr. X. There is no difference between the two heads. The numbers tell what original mold the casting came from. 243 mold was done at GM Research, the 799 mold is used by other vendors. The same vendor will have 243 and 799 molds. The numbers are just a GM system for when the mold was made. If a head had a problem it helps them track down where the problem started. The only difference between the heads is production variance. Case closed. Thanks to Bob and Mr. X. Mr. X machined the first 243 heads himself at GM Research.
Old Apr 5, 2007 | 08:37 AM
  #126
BC Bob's Avatar
BC Bob
Amen
Old Apr 5, 2007 | 11:13 AM
  #127
BADC64GO's Avatar
BADC64GO
Now that is solved we can focus on the problem of low dyno numbers. First, that is pretty good numbers for the mods you have done, would be nice to be a little better. I would look at the problem in this order.
1. Your tuner and the software he used, not all are alike (or good) I race a LS1 and only HPTuners software is used.
2. Fuel - Injectors and fuel pump could be a small marble in the funnel.
3. Go back and check everything on the air in take system you installed. And understand on a dyno the intake system is not going to do you much good as there is no ram air effect. (forced air)
Good luck.
Old Apr 14, 2007 | 06:28 PM
  #128
tootired's Avatar
tootired
Default Heads
243s here. Build on 11/13/2006.
Interested to see if there are any real differences.
Old Apr 16, 2007 | 01:09 AM
  #129
bassmechanic's Avatar
bassmechanic
After reading this I checked my SS Silverado when I was washing it earlier and the passenger side iss 317 and drivers side started with a 2. I have a bad back and could not reach to move the hose out of the way blocking my view.
Old Apr 18, 2007 | 09:02 AM
  #130
z060ntrack's Avatar
z060ntrack
WOW
How about the deck height, would it be the same compression ratio?
Old Aug 7, 2007 | 02:05 PM
  #131
Corvette Don's Avatar
Corvette Don
From what I have heard is that the 799's ar a sand cast head where are the 243's arent
Old Aug 8, 2007 | 12:49 AM
  #132
CMY SIX's Avatar
CMY SIX
Default hp
2006 mn6 243 heads just pulled 364rwhp with just a predator 93 octane tune with 91 octane fuel, just put new 91 tune in the other day it feels like that gave it even more, car is bone stock!!
Old Jul 29, 2008 | 11:56 AM
  #133
BeachVette6's Avatar
BeachVette6
Build date 11/07 799 heads
Old Jul 29, 2008 | 12:19 PM
  #134
Dogue's Avatar
Dogue
Not this old thread....
Old Jul 29, 2008 | 12:41 PM
  #135
ATC399's Avatar
ATC399
yep its back
Old Jul 29, 2008 | 02:05 PM
  #136
C6 Doberman's Avatar
C6 Doberman
Since it is back.........
FWIW my car has one 799 head on the drivers side.
Cam only 451rwhp/428rwtq
Old May 8, 2009 | 02:45 AM
  #137
therealhitman's Avatar
therealhitman
St. Jude Donor '10
Default Since you bumped the thread....
Originally Posted by 300mph
Oh no!!! I just checked mine and I have 66L heads.
GM has really screwed up this time. What should I do???
I'm still rolling on that one!!!
To Calling all LS2 Experts
Old May 8, 2009 | 08:50 AM
  #138
NYC6's Avatar
NYC6
Do I have this right...You open a long dead thread to laugh at a 2 year old post?
Old May 8, 2009 | 09:13 AM
  #139
vettl83's Avatar
vettl83
To help your survey my previous 07 build date 11/06 243 heads.
Old May 8, 2009 | 12:07 PM
  #140
therealhitman
St. Jude Donor '10
Default Take it easy chief...
Don't get yer panties in a wad. I didn't dig up the dead body, I just kicked the skull around a little.
