LS7 Cam in MN6, C6
Old Mar 21, 2007 | 08:16 PM
maj75's Avatar
maj75
Default LS7 Cam in MN6, C6
I did a search and could not find the answer.
If you could get a deal on an LS7 cam, would it be worth installing in a 6 speed manual C6?
Would you need to replace any other parts in the valvetrain?
Old Mar 21, 2007 | 09:24 PM
chemten's Avatar
chemten
maybe the springs. the stock springs suck and the stock cam has low lift compared to the ls7.
Old Mar 21, 2007 | 09:39 PM
CYA-Vett's Avatar
CYA-Vett
It would be a complete waste of time/money. With the cost of labor involved, the price of the cam is negligable. Go bigger, please do not open up a perfectly good motor and lose your warranty for minimal results.
Old Mar 22, 2007 | 06:21 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Data for consideration
These are some of the cams I am considering:
Vendor . . . . . . . duration . . . lift . . . . lobe sep
<Comp Cams . . . 222/230 - .581/.591 115LSA>
<Comp Cams . . . 224/230 - .581/.588 114 LSA > XER273HR
<TRcheatR . . . . 215/230 - .601/.578 117LSA>
<LPE GT-11 . . . . 215/231 - .631/.644 118LSA>
<Crane . . . . . . . 216/224 - .585/.585 114LSA > HR-216/344-2S-14
<LS2 stock . . . . . 204/211 - .525/.525 116LSA>
<LS7 stock . . . . . 211/230 - .591/.591 ???LSA>
Can someone help me out with the lobe separation angle on the LS7 stock cam? Thanx.
Old Mar 23, 2007 | 09:09 PM
CYA-Vett's Avatar
CYA-Vett
211/230 591/591 120 LSA
Old Mar 23, 2007 | 09:51 PM
F1_SS's Avatar
F1_SS
Will the cam even fit?
Old Mar 23, 2007 | 11:20 PM
TTRotary's Avatar
TTRotary
120 LSA...wow. Why so wide? Smog?
Old Mar 24, 2007 | 01:59 AM
tjwong's Avatar
tjwong
For a nice smooth idle and of course smog. I haved a 2006 LS7 cam that was taken out of a car with 1200 miles. If anyone is interested in it you can just PM me.
Old Mar 24, 2007 | 02:21 PM
Wallacefl's Avatar
Wallacefl
LS7 might work on par as the CHEATR or LPE GT-11...like to see someone do it in L92/76 combo on LS2
Old Mar 24, 2007 | 02:40 PM
chemten's Avatar
chemten
when compared and remembering that the actual lift of the ls7 is more than just comparing the cam lift numbers(since it has 1.8 rockers instead of 1.7), the adjustment is very close to both of those cams if switching to 1.8 rockers. would be interesting to see a curve with a 120 lsa. it might be pushed too far and the redline needing to be adjusted on the ls2 to get max power.
Old Mar 24, 2007 | 03:12 PM
AU N EGL's Avatar
AU N EGL
This is the third cam Chevy used to get the HP DOWN to 505.
To LS7 Cam in MN6, C6
