autocrossing Questions
Old Mar 29, 2007 | 03:40 PM
xfiremd's Avatar
xfiremd
Default autocrossing Questions
I tired searching but could not find what I was looking for. I am trying to get info about what kind of setup all of the autocrossers are using.
It seems that cat back dont do much for the C6 on the dyno but what about weight savings?
Has anyone found cheap lighweight track rims?
What tires are you autocrossers using?
Has anyone got into testing different front sway bars?
Has anyone tried differet shocks, or is anyone valving shocks for solo?
Old Mar 29, 2007 | 04:31 PM
jterp's Avatar
jterp
I won the local superstock class last year running my Z51 in bone stock configuration.
Old Mar 29, 2007 | 04:42 PM
bdking57's Avatar
bdking57
If you want to run stock... look into pfadt poly sway bar bushings, some hoosiers, and upgrade your shocks, then have the suspension set up properly.. personally I think running SS is boring, winning in stock form to me isnt as fun as getting out there with a sick sounding car and let it rip.
Old Mar 29, 2007 | 07:22 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
This may be a great place to ask the question, but for a multitude of answers, go back to the the front page of CF. There, if you page down, you'll see an entire forum of autocrossing/racing. I suspect you'll get every answer across the spectrum to your question.
Old Mar 29, 2007 | 09:23 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
What is your budget?
Best bet is stock until you figure out what YOU need.
Old Mar 29, 2007 | 11:14 PM
aseipos's Avatar
aseipos
Originally Posted by bdking57
If you want to run stock... look into pfadt poly sway bar bushings, ...
Poly bushings are not allowed in SCCA stock autocross classes, are they?
Old Mar 30, 2007 | 12:55 AM
C6400hp's Avatar
C6400hp
Yes they are.
Section 13.7 top of page 63
http://www.scca.com/_FileLibrary/File/2007SoloRules.pdf
To autocrossing Questions
