Header Recommendations
Old Apr 1, 2007 | 06:35 PM
Wrazor1's Avatar
Wrazor1
Default Header Recommendations
Ok, just getting ready to buy headers (most likely Kooks). Should I go with a 3/4" or 7/8" if I am going to add a heads/cam package? Cam will be an LPE GT11 and I will most likely use AFR 205 heads. I'm buying a Callaway Honker CAI as well.
So which size should I be looking at? AND I already have a Corsa Sport Exhaust with their XO pipe and need to know if I need a complete header system or just the long tube headers only?
Last thing, where is the best place to buy Kooks headers?
thanks for all of your help folks!!
Old Apr 1, 2007 | 07:07 PM
knkali's Avatar
knkali
Tbyrne (sp) seems to always have good prices when I was checking $$
Old Apr 1, 2007 | 07:27 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Go with Kooks 1 7/8
I did the lpe 403 wih that cam with great results
I also bough the headders from tbyrne
Old Apr 1, 2007 | 07:46 PM
Wrazor1's Avatar
Wrazor1
Originally Posted by burtonbl103
Go with Kooks 1 7/8
thanks for the replies, I forgot to ask if you had any drone with your headers or does that usually occur with the exhaust? Still pretty new to this stuff.
Old Apr 1, 2007 | 08:09 PM
dennis50nj's Avatar
dennis50nj
go with the 1 3/4 unless you are going to cube the motor over 383
Old Apr 1, 2007 | 08:14 PM
AU N EGL's Avatar
AU N EGL
all LTs have some drone.
Old Apr 1, 2007 | 08:22 PM
saplumr's Avatar
saplumr
Unless you plan on "very extensive mods" you need 1-3/4 only, in the manufacturer of choice. Everyone has there own favorite...so take your pick.
Old Apr 2, 2007 | 02:22 PM
Wrazor1's Avatar
Wrazor1
thanks guys!
Old Apr 2, 2007 | 03:40 PM
Ultimate CC's Avatar
Ultimate CC
i think im going for the 1 3/4 for my c6
Old Apr 2, 2007 | 04:52 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Anyone know anything about TTS headers? Got a chance to buy some but need to move very quickly. Thanks
Cajun
Old Apr 2, 2007 | 07:58 PM
crabman's Avatar
crabman
The conventional wisdom goes back to before I was old enough to drive. At that time everyone knew the rules. Big block, bigger tubes, small block, smaller tubes. Except of course for highly modified small blocks which would suffer on the top end without the bigger tubes and were an accepted exception to the rule. A lot has changed since then.
Does the conventional wisdom hold up? Well, lets see. I first began reading where some tuners were saying that they were not seeing a lower rpm loss with the 1 7/8 tubes. Pretty soon I started seeing runs from actual owners who had them installed and didnt lose anything compared to their smaller tubed brothers. Not all that long ago I went ahead and installed the 1 7/8 tubes on mine. I made more power than a set of LGs that were installed the day before with nearly identical conditions. Everywhere. Curve was very similar. Its hard to argue with real results proved out on your own car even when your a skeptic like me.
IMO the LS2 appears to be capable of running 1 7/8 without giving up anything on the bottom to mid range while giving you more headroom. Dont pass them up without careful thought, especially if you might be modding further.
To Header Recommendations
