What causes cam failure?
Old Apr 24, 2007 | 01:10 PM
mfoti's Avatar
mfoti
Default What causes cam failure?
Noticing some threads of aftermarket performance cams that have been pulled and noticed to be chewed up, metal in the engine, etc. Is this a screwed up install or does the cam swap come with additional risks that aren't openly discussed. I know dual springs are a no-brainer but other than a dropped valve what is the potential for a problem?
Old Apr 24, 2007 | 02:19 PM
dbradley's Avatar
dbradley
Most of these threads refer to flat tappet cams, not rollers. With recent changes in chemistry in engine oils to meet government emission requirements, the oils don't provide needed lubricity for the lifter/lobe break in procedure for older styled engines. The use of oils such as Delo or Rotella and GM EOS will help to prevent the failure on startup. These products still have the 'old' formulas and seem to prevent the dreaded first time startup failure.
Old Apr 24, 2007 | 02:25 PM
johnodrake's Avatar
johnodrake
Moderator
I would guess a poor install - including an improperly lubed cam. I would always use a known, reputable installer.
Old Apr 24, 2007 | 03:54 PM
andreas g.'s Avatar
andreas g.
billet cams, hardened cam lobes, plus roller lifters, equals no cam failures that I've ever heard of on LS type motors. If they exist at all there very rare. I think a cam my simply break in two before they would go flat as they say.
Old Apr 24, 2007 | 04:04 PM
EuroRod's Avatar
EuroRod
Like they say, cam failures are pretty darn rare these days, with roller lifters. Extreme valve spring pressure is one source of potential cause, but they usually cause the roller to fail first. I'd speculate that it could be improper adjustment. However, when they do fail, is a royal PITA, for sure.
Old Apr 24, 2007 | 04:16 PM
mfoti's Avatar
mfoti
So if a roller/lifter fails can/will that trash an engine?
Old Apr 24, 2007 | 04:54 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
As long as the cam is porperly installed with the necessary valvetrain upgrades, I don't see there being many failures. I would trust an aftermarket cam in my engine more than I would aftermarket rockers. JMO
Old Apr 24, 2007 | 05:44 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
You must use an oil with zinc etc. to break in a new cam on an old engine and I would do this for sure on a new engine as well.
To What causes cam failure?
