Nut Size
Old May 10, 2007 | 10:08 PM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Default Nut Size
Anyone know the size of the rear nut that holds the rear bearing hub on?
Looks like maybe 1 1/2 inch??
HELP !
Old May 10, 2007 | 10:21 PM
Ranger's Avatar
Ranger
HELP !
Believe you mean the rear axle nut. I use a 34mm deep well socket on mine. Some say 33mm is a better fit. Torque spec is 118 foot-pounds.
The axle nuts tend to get loose and need periodic checking.
I've used Lockite Blue on my axle nuts and, since applying it, mine have remained at proper torque values thru two track rentals and numerous passes down the 1320'.
Ranger
Old May 11, 2007 | 02:03 AM
LOS ANGELES PI
Loose is an understatement.
I was track prepping my car this eve and saw the pass side almost backed off, and the drivers side could be turned easily.
Both torqued up.
Scary stuff
To Nut Size
