C6 Coolant Temp
Old May 18, 2007 | 09:25 PM
Dragin's Avatar
Dragin
Cruising
Default C6 Coolant Temp
At what temp should the fans kick in? Is it normal to see 240 degrees on the DIC display for Coolant Temp?
Old May 18, 2007 | 09:31 PM
kmthor00's Avatar
kmthor00
awfully hot!
Old May 18, 2007 | 09:39 PM
racerbug's Avatar
racerbug
I live in FLA. and the max I see 208 at any time.
Old May 18, 2007 | 09:40 PM
cbrf4i1's Avatar
cbrf4i1
it starts to kick in %. around ect 195* fan is about 20%, at your temp / 240* fan should be on 100% already.
Old May 18, 2007 | 11:23 PM
rustyguns's Avatar
rustyguns
man you should never see 240 with normal driving up to 110 degree days
Old May 18, 2007 | 11:46 PM
glennhl's Avatar
glennhl
Have you replaced your coolant for any reason. You'll get temps like this if you don't get it refilled all the way because of an air pocket.
Old May 19, 2007 | 04:57 AM
4evervette's Avatar
4evervette
i think it in the high side
Old May 19, 2007 | 08:58 AM
VET4LES's Avatar
VET4LES
Are you sure your not looking at the oil temp?
Old May 19, 2007 | 10:21 AM
vette-oholic's Avatar
vette-oholic
yea i usually only see about 225 max when running the car hard
Old May 19, 2007 | 10:25 AM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Are yuo sure you you are talking about coolant temp
sounds like oil to me
if not you should get it to the dealer fast
To C6 Coolant Temp
