Front rotors cracked
Old May 30, 2007 | 12:50 PM
Morrisman's Avatar
Morrisman
Default Front rotors cracked
I have an '06 C6 Z51 MN6 with 6,500 miles on it. The front rotors have small cracks coming off of every drilled hole in the front rotors, All cracks are about 1/8 inch. 2 cracks per hole. Rear rotors are fine. Any body heard of this happening before? I did do a couple of track days over the last 2 weeks and used my brakes to their limit. All brake parts are stock. I did use RA1 track tires which have far more grip than stock tires.
Old May 30, 2007 | 12:53 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
No Z51 here but IIRC I think I read in previous threads that drilled rotors will develop cracks after being tracked...
Do a search in the archives.
Old May 30, 2007 | 02:02 PM
JLMounce's Avatar
JLMounce
This is common with drilled rotors, and why you'll hardly ever find auto-x and road race enthusiests running drilled rotors.
Old May 30, 2007 | 02:15 PM
Michrider's Avatar
Michrider
Brake pads, rotors, and fluid are consumables at track days. Plan on changing everything after a good day at the track. I'd be surprised if rotors weren't wiped out after a hard track day. Besides pads, rotors, and fluid, consider overhauling the calipers also with new seals. Especially if the brakes got hot enough to boil the fluid and crack the rotors. That much heat cooks the caliper seals.
SOP for a race team after a couple hours of track time is to pitch the pads and rotors and overhaul the calipers. You've got to pay to play.
Old May 30, 2007 | 03:59 PM
AU N EGL's Avatar
AU N EGL
This is normal for any rotors with holes in.
Old May 30, 2007 | 04:24 PM
EuroRod's Avatar
EuroRod
With only 6500 miles, I'd approach the dealer for replacement under warrenty. And remember these seven words, "No, I have never tracked this car"!
Old May 30, 2007 | 04:32 PM
Morrisman's Avatar
Morrisman
Thanks guys
Old May 30, 2007 | 04:33 PM
Wayne O's Avatar
Wayne O
CF Senior Member
From what I've heard this is not uncommon with drilled rotors and the problem isn't necessarily resulting from track use. Accordingly to the Godfather of the C6 (Dave Hill) drilled rotors are 'just for looks.'
I would certainly try to have them replaced under warranty. I wouldn't go so far as to suggest you lie about (not) running the car on a track but I wouldn't mention it unless the subject comes-up either.
Old May 30, 2007 | 06:28 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Mine had cracks just like that, but I just left them for about 6 months because they worked fine. (No track time during those months) Eventully, I replaced them because they warped.
If you go this route, be sure to thoroughly go over the car and pick off all the pieces of rubber. But the look of your tires will probably give it away anyway.
Old May 30, 2007 | 09:53 PM
Keaka26's Avatar
Keaka26
Drilled rotors are definitely all aesthetics. The cool air passing through the scorching hot drilled rotors will cause uneven thermal expansion of the metal, causing the stress fractures around the holes....Get yourself some solid rotors
Old May 30, 2007 | 11:38 PM
martinblank's Avatar
martinblank
Default Baer
It’s a very common problem. I have a Z-51 and replaced my stock with Baer drilled and slotted. And Hawk pads. Seems like a lot of people on the Forum, when they have rotor problems, go this road. In the end I really don’t care about what it looks like, but as the Baer rotors are lager than stock, it really improved the appearance, to me anyway. It’s really a great set-up and my favorite mod so far.
Old May 31, 2007 | 12:42 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Brakes are a wear item, especially if you will be tracking the car to the extent that you are and "using the brakes to their limit". It seems like you just wore yours out.
Time for new ones if you are going to be tracking the car to the degree that you are.
Old May 31, 2007 | 08:15 AM
AFVETTE's Avatar
AFVETTE
There's your answer. As other's have said tires and brake components are "consumables" especially when tracked. But your dealer may replace then under warranty, if nothing else you’ll get some new OEM Z51 rotors for use should you sell the car and it records another “rotor failure” to GM who may use that info to make design changes.
I track my C6 Z51 and plan on replacing my OEM Z51 rotor's with the Aussie DBA Series 4000 6X6Wiper-Slot rotors. $650 for all four (shipped). PM me for a source. Take a look - http://www.dba.com.au/2006/products_4000.asp
I saw these in use first hand at Road America this past April. RA is known to be very hard on brakes with its 3 long straights where the Z06's approach 165 MPH. They are wicked good of us weekend warriors.
Tom
To Front rotors cracked
