Cold Tire Pressure
Old Jun 4, 2007 | 11:10 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by 072LTC6Z51
A good rule of thumb is 1 psi + or - for every 10 degrees .. .
Old May 29, 2019 | 09:29 AM
juanvaldez's Avatar
juanvaldez
Factory track tp is 26psi.
Old May 29, 2019 | 02:42 PM
dr_gallup's Avatar
dr_gallup
Originally Posted by 6spdC6
I do mine in the morning aftewr the car has sat all night.
OBTW there have been a few threads abou the accuracy of the system.
My system (and a lot of others ) is ALWAYS a couple pounds higher than the good digital gage I use to set tire pressure. Not a problem if you know the difference is there, you just allow for it.
I use a Joes Racing analog gauge with a bleeder valve when setting mine. Over inflate a PSI or two and bleed it down to the exact pressure. TPMS agrees exactly.
Old Aug 12, 2020 | 12:38 AM
oldvetteowner's Avatar
oldvetteowner
I have my 2019 Vette's tire pressure at 30lbs. I really don't have to worry about high temperatures in Juneau. It hit 82 last month but that was the highest it has been all Summer The garage I keep the car in has a steady temperature of about 55 even in the Winter unless some one leaves the door open
Old Aug 12, 2020 | 08:13 PM
red62vette's Avatar
red62vette
28-29 cold. Rides and handles well and it may mitigate cracked wheels just a bit.
