Cold Tire Pressure
Old May 31, 2007 | 01:58 PM
NJAg78's Avatar
NJAg78
Default Cold Tire Pressure
I haven't looked hard enough at the door sticker that tells the cold tire inflation pressure so if this is answered there, my apologies.
Since the pressure insde a fixed volume is temperature dependent, at what temperature (ideally) should cold tire pressure be measured. Tire pressure measured on a 50 degree morning before sunrise will be different from the pressure measured with the car sitting in an aspalt parking lot or driveway on a sunny 90 degree day (three to five PSIG).
My car seems to be extremely sensitive to tire pressure and I would like to get this close to right
Old May 31, 2007 | 02:37 PM
6 speed Sid's Avatar
6 speed Sid
30 psi- cold-where ever you are.
Old May 31, 2007 | 03:40 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I do mine in the morning aftewr the car has sat all night.
OBTW there have been a few threads abou the accuracy of the system.
My system (and a lot of others ) is ALWAYS a couple pounds higher than the good digital gage I use to set tire pressure. Not a problem if you know the difference is there, you just allow for it.
Old May 31, 2007 | 04:20 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by NJAg78
... Tire pressure measured on a 50 degree morning before sunrise will be different from the pressure measured with the car sitting in an asphalt parking lot or driveway on a sunny 90 degree day (three to five PSIG). ...
you will also notice a difference side-to-side depending upon which side the sun hits.
i've always taken 'cold' to simply refer to, before the car is used and heat has been built up in the tires from road use.
Old May 31, 2007 | 06:04 PM
haljensen's Avatar
haljensen
"COLD" to Chevy means ambient air temperature. 30#'s if it's 30° or 90°. you have to add air in cold temps and release air in high temps. So far Chevy doesn't have Automatic Tire Air Pressure Regulators.
(and if they did it would be a $1295 option with a $200 a year charge to keep it activated.)
Old Jun 1, 2007 | 11:01 AM
Buffy's Avatar
Buffy
I use the seasonal mean low temperature for "cold". The National Weather Service publishes that information, but you probably know about how cold it is in the morning where you live anyway.
Around here, its about 30 degrees in the winter and 60 degrees in the summer, I don't bother with finer increments than that. This corresponds to about 3 PSI difference, so I put some air in in the spring and let some out in the fall.
Best thing to do is set them first thing in the morning, before the sun has shone on them. If need be, adjust for the current temperature at a rate of 1 PSI per 10 degrees F - that is to say, if your normal morning low is 60 degrees F but its 50 that morning set them to 1 PSI lower than your nominal value.
Old Jun 1, 2007 | 11:18 AM
MADMAX1's Avatar
MADMAX1
I use nitrogen and it pretty much stays constant @ 30 psi.
Old Jun 1, 2007 | 11:36 AM
robvuk's Avatar
robvuk
Only if your temps are constant or you've figured out how to defy the laws of physics. Namely the ideal gas law. PV=nrT.
Old Jun 1, 2007 | 12:06 PM
Ranger's Avatar
Ranger
Getting good mileage from these expensive runflats involves setting the cold psi to 30 and keeping an eye on it. Requires tinkering with seasonal temp fluctuation. I try to keep the normal hot psi at no more than 34.
Remaining in this 30C-34H range requires me to tweak the valve steams a couple times a month.
Hard to find free air at gas stations these days. Only one still has it in my area.
Ranger
Old Jun 1, 2007 | 03:20 PM
vetdude's Avatar
vetdude
Ranger
Dude, I can't believe you don't have your own portable air pump?
Set mine at 30psi cold after car has sat overnight, regardless of ambient temp.
Old Jun 1, 2007 | 03:22 PM
vetdude's Avatar
vetdude
30 psi cold. But be warned, these tires even come with a warning message regarding lack of traction when outside temps fall below freezing. Punch it when it's below 32 outside and the tires are cold you'll wind up in the weeds!
Old Jun 2, 2007 | 10:59 AM
Whiterock1's Avatar
Whiterock1
I've used 32psi on every car I've owned, and do on the C6. Cold, I see 31 then quickly to 32 on the rr, 32 on the others. Hot, they go to 36-37 when driving, shall we say, quickly. If they go over 37 hot in the summer, I'll lower to 31 cold, otherwise this gets me best tire wear and still excellent handling.
Old Jun 2, 2007 | 11:43 AM
abrimberry's Avatar
abrimberry
Cruise-In II Veteran
I have kept my run flats at 28 psi cold for years. I have been getting 20,000 - 25,000 miles from my tires. When I kept them at 30 psi, I found the center of the tire wore faster. I remember reading the 28 psi tip on Corvette Forum many years ago. YMMV.
Old Jun 2, 2007 | 12:35 PM
VET4LES's Avatar
VET4LES
At 12,000 miles I noticed my rear tires were waring in the center. I have since lowered the rears to 28 and hope it corrects the problem. I had the alignment check and the rear was OK but the fronts were toed in and wearing on the outside.
Old Jun 2, 2007 | 02:58 PM
jimmie jam's Avatar
jimmie jam
i have never had a problem doing this. hot they run up to 31-32 - perfect.
Old Jun 3, 2007 | 03:35 PM
calemasters's Avatar
calemasters
Yes. And then you have to adjust your tire pressure to compensate for ambient temperature changes.
Old Jun 3, 2007 | 03:46 PM
dennis50nj's Avatar
dennis50nj
24-25lbs cold gets best traction ride handling and wear. bad gas mileage
To Cold Tire Pressure
Old Jun 3, 2007 | 04:28 PM
072LTC6Z51's Avatar
072LTC6Z51
A good rule of thumb is 1 psi + or - for every 10 degrees above or below 70 degrees. Example: if it's 80 degrees outside and your cold tire pressure should be 30 psi (cold/70 degrees) then, at 80 degrees it should be reading 31 psi. At 60 degrees outside, 29 psi. Check the pressure when the tires are "cold" meaning not driven on for at least 3 hours and not sitting in the sun. I know everyone has their opinion on how they do it but this is how I do mine. Learned it from a very experienced EVOC instructor who had extensive knowledge about vehicles and tires. I have never had any issues with tire wear or anything else.
Old Jun 3, 2007 | 05:50 PM
johnodrake's Avatar
johnodrake
Moderator
I use pretty much 78% Nitrogen 21% Oxygen and it stays at 30psi - unless the ambient temp goes up or down markedly..... My tpms and digital gage read pretty much the same.
Old Jun 3, 2007 | 09:02 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Nitrogen has nothing to do with it.
