Lug nut torque spec
Old Jun 8, 2007 | 06:28 PM
running man's Avatar
running man
Default Lug nut torque spec
Can anyone tell me what the torque should be on our lug nuts?
Old Jun 8, 2007 | 06:35 PM
AU N EGL's Avatar
AU N EGL
100 ft lbs
Old Jun 8, 2007 | 06:38 PM
mousey007's Avatar
mousey007
Default Lug Nuts
Don"t forget to retorque after a couple of days if you are installing new wheels.
Old Jun 8, 2007 | 07:02 PM
running man
Thanks, I just put on new wheels, so I'll check them again next week.
Old Jun 8, 2007 | 07:17 PM
AU N EGL's Avatar
AU N EGL
Did you remove those little seraded washers used to hold the brake rotors on? They should have been removed in dealer prep.
Old Jun 8, 2007 | 10:08 PM
runutzzzzz's Avatar
runutzzzzz
Really?
Old Jun 8, 2007 | 10:42 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Yup.
Old Jun 8, 2007 | 10:52 PM
calemasters's Avatar
calemasters
No.
Old Jun 9, 2007 | 07:00 AM
AU N EGL's Avatar
AU N EGL
what do you know it is not on there for the C6, it was for the C5s. Anyway take them off if your useing aftermarket wheels.
The stock wheels have a slight depression on the inside of the wheel for that washer to fit. Most aftermarket wheels do not.
Besides that little washer is really only need to hold on the rotors in the manufacturing process untill the wheels are put on. After that they serve no purpose.
To Lug nut torque spec
