Shorties vs. Long Tubes
Old Jun 25, 2007 | 01:49 AM
VetVetter's Avatar
VetVetter
From: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
St. Jude Donor '09-'10
From what I have been told by reputable shops, the issue with long tube headers is that it relocates the factory position of the cats ... by interpretation of the law, that is "modifying" the OEM design and thus (regardless of emmission effect itself) illegal.
The Calloway shorty headers maintain the OEM cat location - and if you were to use the factory installed cats, you would be complying with the fed reg since you are using the original cats and the exhaust manifold/shorty headers are not part of the emmission system.
Old Jun 25, 2007 | 08:21 AM
VET4LES's Avatar
VET4LES
That's correct, the problem is Callaway headers are not CARB approved. Many states besides California require it.
Old Jun 25, 2007 | 01:08 PM
FloydSummerOf68's Avatar
FloydSummerOf68
It looks like the callaway headers provide about 7rwhp from some sites I've seen selling callaway products.
NOT worth the money in my opinion.
Old Jun 25, 2007 | 01:20 PM
VetVetter's Avatar
VetVetter
Ah - that's the rub. Gotcha.
Old Jun 25, 2007 | 01:51 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Originally Posted by crabman
(However, enforcement of this requirement is almost non-existent and is the primary loop-hole that allows the usage of so-called "high flow" catalytic converters. Many of these units are sold with the disclaimer as being a "race" component and are not intended for street use.) Due to the hundreds of vehicle models produced over the years, it is virtually impossible to determine by glancing under a car whether the converter is the original unit, a legal OEM replacement, or a non-legal aftermarket "high flow" performance unit. Unless CARB or the EPA decide to take more aggressive enforcement action, the installation and usage of these non-exempt "high flow" catalytic converters will likely continue.
Bingo!
Old Jun 25, 2007 | 03:05 PM
Buffy's Avatar
Buffy
Well, there is some information available.
Callaway claims 19 HP for "power group 1", which is a Honker and catback. They claim 47 HP over stock by adding "power group 2", which is the headers, an intake manifold and wires. And they claim 90 HP over stock by adding power group 3, which is a cam and heads.
So, just assuming that its half intake and half exhaust, that makes the headers worth about 14 HP (by their claims).
Which ain't great, but it ain't nothing either.
Most folks seem to get about twice that from longtubes, but there is one other factor ...
The longtubes are used with replacement high-flow cats, or no cats. So how much of that 30 HP or so gain is from the headers and how much from the cats? Random claims about 10 HP for their cats, so the short headers with Random cats could be around 25 HP or so - pretty close to the long tube headers. Of course that isn't legal either, with the replacement cats, but the cats would be fairly easy to swap out for inspection day.
Of course these are manufacturer's claims, and you milage may vary. But Callaway is pretty reputable, and Random's been around for a while, so it isn't like something advertised on late-night TV. Callaway's overall numbers - CAI, headers, intake, cam and heads adding up to 90 HP - is easy to believe - if anything, that sounds a little low. On the other hand, 19 HP from intake and catback sounds a little optomistic.
There's certainly one advantage to the short tube headers over the stock manifolds - they're equal length tubes, which the stock manifold isn't. I'm not sure that the equal lengths aren't more important than exactly what that length is. But I don't have dyno numbers to prove that, so ..
Old Jun 25, 2007 | 03:25 PM
VET4LES's Avatar
VET4LES
Good information, thanks.
Old Jun 25, 2007 | 03:28 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
5-7 RHWP loss with the shorty vs Long Tubes. Long Tubes scavenge mo betta.
Old Jun 25, 2007 | 03:51 PM
TommyV's Avatar
TommyV
Callaway claims 8-10 hp with the shorties.
