Why do Corvettes run so hot?
Old Jun 24, 2007 | 01:44 PM
Razrback16's Avatar
Razrback16
Default Why do Corvettes run so hot?
I'm getting ready to purchase an '08 Vette but I still have my S/C 97 Cobra Vert in the meantime. From the reading I've done on this forum and other places the Corvettes seem to run up around ~220 as a running temperature whilst all of the Mustangs I've had run around 195-200 as running temperature. Is there a reason for the increase in temperatures on the Vette?
Old Jun 24, 2007 | 01:55 PM
EuroRod's Avatar
EuroRod
Strictly an emissions issue with all GM engines, I suspect. High operating temps leave little margin for error, hot cabin temps, and is rough on oil (don't care what the syn boys say!)and gaskets and seals. I run a big radiator, oil cooler, electric water pump and a 160 t'stat. Car still passed emissions, runs cool, cool cabin temps, and after 6k miles, oil is still like new. I'm sure the gm engineers have reasons for the high temps, but damned if I know what they are!
Old Jun 24, 2007 | 01:58 PM
Vette_DD's Avatar
Vette_DD
You've been reading some posts where someone was really pushing the C6 or else they were spending lots of time in slow traffic.
I've had 3 C6s and all 3 would run about 197-200 degrees when driving continuously anywhere from 30-45 mph. If I'd get it on up to about 60-70 mph, the temp. would drop slightly to about 196.
Only when I'm in really slow traffic, or sitting at a drive-thru does the temp get up to about 205-210. I've never seen temp. greater than 215.
Old Jun 24, 2007 | 02:04 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
It's for emissions. Just swap out the T-stat for a 160 deg. and you'll be fine. To get full benefit from it, get a tune.
Old Jun 24, 2007 | 03:10 PM
VET4LES's Avatar
VET4LES
Normal driving mine runs 196. If I doing something different like sitting in heavy traffic on a hot day I have seen 220 but am not concerned about it.
Old Jun 24, 2007 | 07:47 PM
J02ws6transam's Avatar
J02ws6transam
hey guys i have made a huge discovery for making the vettes run cooler... i have a 05 c6 6spd with a ati procharger with a 160 thermostat in the car. i was originally running anywhere around 195-205 depening how bad i was getting on it because that procharger makes alot of heat. that was too hot for me. i have the efi live program so i went in there and played with the fans and i have them so they turn 90% work load all the time and now no matter how hard i drive my car it will not go over 180. normal driving im around 174. huge difference. that 20 degrees cooler just by having the fans stay on. hopw this helps you guys, and also with the procharger i can feel the difference in power that the 20 degrees gives to as well, i was told by my dyno shop owner that its worth about 10 rwhp. good luck everyone.
Jon
Old Jun 24, 2007 | 08:03 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Jun 24, 2007 | 08:09 PM
overrev64's Avatar
overrev64
Changing to a lower temp stat will not make the engine run cooler. It will only allow the coolant to start flowing through the engine at a cooler temperature. If you are stuck in traffic with no airflow through the radiator, the engine temp will climb regardless of thermostat. The only way to have the engine run cooler without modifying the entire cooling system is to have the fans turn on sooner.
Old Jun 24, 2007 | 08:34 PM
FloydSummerOf68's Avatar
FloydSummerOf68
My car has never seen over 199 degrees
I live in houston too, so it isnt cool :P
I'll check again now that it's REALLY getting hot.
Old Jun 24, 2007 | 08:55 PM
VET4LES's Avatar
VET4LES
Old Jun 24, 2007 | 10:16 PM
cthusker's Avatar
cthusker
After installing a 160 stat my engine temp immediately dropped about 20 degs (on average) in every situation except stuck in traffic. Yes it does climb to 215 to 220 idling in traffic but as soon as I get some airflow going it immediately drops back to around 180. I haven't reprogrammed my fan but that's next on the list..... So for my car the 160 stat dropped my operating temp about 20 degs under most condtions.. end of story!
Old Jun 24, 2007 | 10:24 PM
jschindler's Avatar
jschindler
I think he may be confusing the temps with oil temps. I've had two C6's now - a Z51 and a F55. The coolant ran right at 190 in both cars, unless I was running it hard. The oil temps ran somewhere around 215 - 220 in both of them (about 5 degrees hotter in the non-Z51).
Old Jun 24, 2007 | 11:43 PM
UberR32's Avatar
UberR32
You thermostat and fan changing guys are killing me! If your engine doesn't get up to OEM spec operating temp, your oil won't burn off moisture and your rings will wear at an advanced rate.
Cooler is not always better.
Old Jun 24, 2007 | 11:55 PM
Vette_DD's Avatar
Vette_DD
Actually, he didn't say whether he was talking about engine coolant temps or oil temps. My oil temps run about what yours did.
Old Jun 25, 2007 | 12:05 AM
xs650's Avatar
xs650
OEM spec temperature is what it is for other reasons. If it were only for those reasons it could be lower.
Old Jun 25, 2007 | 01:05 AM
TahoeDrvr's Avatar
TahoeDrvr
Okay, let's hear from some of those tuners or moto-engineers out there who actually know some of these benefits.
I'm an engineer- electrical though. There are some specs that are just meant to be for reasons the average user (me) doesn't really need to know. I don't track my vette. I know cooler temps will give more rwhp, but what are the benefits of hotter temps?
Old Jun 25, 2007 | 01:48 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
For the same reason the Fords ran hot .......... emissions. The 96-97 Cobras were known for running hot, yours must be a one of the later ones produced. (I'm an old Ford guy who has gone to the dark side )
The Corvette is very sensitive to temperature. Once the intake air temperature reaches 86 degrees the VCM begins to pull timing. The guys who race usually install a cold air intake, 160 degree stat and set the fan to turn on sooner. This will reduce the IAT temperature and reduce the effects of heat soak.
There are many pros and cons regarding changing the operating temperature of a car. This subject as well as thow the cooling system functions has been beat to death many times ........ so you can use the search function for one of the many discussions (enjoy ).
If you only use the car for very short trips and never get the oil up to operating temp you are beating the livin hell out of the engine ....... so there are many ways to beat a car
To Why do Corvettes run so hot?
Old Jun 25, 2007 | 07:58 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
What is the reasoning to lead you to believe you won't burn off moisture and your rings will wear faster? Can you give a technical explanation?
Old Jun 25, 2007 | 08:09 AM
cthusker's Avatar
cthusker
I seriously doubt I can get my oil temps under 210 because of a 160 stat. Perhaps that might hold true in cold climates in the winter but I don't drive my car then. When my water temp is at 185 the oil temps are well beyond anything required to burn off moisture. There however is a big sotp difference between water temps at 212 versus 185 degs. At 185 when I stomp it (tracton off) the tires light up in 1st or 2nd grear. At 212 it's not even close to putting down enough power to do that. Don't take the words of dozens of people that have installed 160 stats simply try it! It cost about 20 bucks and 1/2 hour of your time.... It's a very easy cost effective mod if somone is looking for more power under most conditions.......
Old Jun 25, 2007 | 08:22 AM
jschindler's Avatar
jschindler
Yes, we made assumptions. I made mine because Mustangs don't have an oil temp guage from the factory, and the numbers he showed would indicate to me that he meant coolant in the Mustang. That's why I wondered if he wasn't looking at the oil temp guage in the Corvette and confusing it.
