Why do Corvettes run so hot?
I went to the track 2 weeks ago for the first time with the Vette, 06 manual Z51.
Raced from 6-7 pm, in the sun, track temp were 93 rolling through the staging lanes like stop and go traffic for about 10 mins before running..
3 runs.. Between 13.3-13.5@106-108mph
Let the car cool off and waited until sundown and raced 3 more times between 9-10pm. Track temp of 74
3 runs, 12.7-12.8@112-113.5
Since I have installed a CAI and looking into a 160 stat and maybe a tune.
The big advantage to the 160 degree stat is that engine temps both IAT and coolant temps pull timing when they get too hot. The IAT sits in the MAF which is mounted on top of the upper radiator hose. It can pull 12 degrees timing. 20-30hp.
Regarding the water boiling off, consider the following scenario:
1. Car has armchair engineer cooling devices installed, owner takes a short trip, car doesn't get up to operating temp, some condensation remains.
2. Stock car warms up during short trip, boils off condensation.
Regarding the wear issue, I recall seeing a GM document on this forum that discussed advanced wear rates at sub-spec operating temp. It makes sense to me - the cylinder wall is Cast iron, the piston is AL, the rings are some type of hard alloy steel. The coefficients of thermal expansion are all different.
Go read the Z06 forum to hear about the guys removing the external oil cooler and installing an oil/coolant cooler to HEAT the oil. You can also reference any automotive owner manual for the past 20 something years regarding short trips and severe duty classification.
Anyways, I'm just frustrated that both sides of this argument are not fully covered enough on this forum.
If you've turned your Vette into a drag racer and need to hot lap it without the heat induced timing reduction, then you may want to do all kinds of aftermarket mods to keep it cooler. But for 99% of the street drivers, just drive the car and quit worrying about the temps.
A voice in the wilderness
Yes, but those "sub-spec" temps were much, much lower than running at 160 to 190 degrees.
Gee, I though I covered the severe duty classsifation in the last paragraph of my post #17. In regard to your frustration, there are plenty of threads regarding coolant temperature & oil temperature in which both sides of the argument are clearly discussed.
Those of us who do play with changing & modifying engines are well aware of the pros & cons....... we insure that the oil temp is warm before we beat the car.......it is just common sense.
When cars had carbs you had to wait to get on it because the choke would lock out the secondaries. Individuals think that because fuel injected cars just start without touching the gas pedal ....... there is no need for them to reach operating temperature to "go fast" ...... duh
We realize that you can damage the engine & etc..... You do not have to be a rocket scientist to realize that you can not beat a car just after it starts and expect it to last.
It is not our fault that some of the Z06 guys can not wait until their oil gets to operating temperature to beat it ........ GM did not put the oil temp on the DIC to be cute
If you know what you are doing and maintain the car it will last. I drove a 89, 5.0 liter Mustang as a daily driver from 91 - 05. I installed a vortech supercharger with 10 PSI of boost, with 160 stat, larger radiator, cooling fan set to 160. Nothing other than normal wear.
Now if you only drive a car a few miles to work each day. The oil never gets warm, and trouble starts.
The software engineers that programmed the PCM to pull timing at high coolant temps and high IAT temps dont eat at the same table as the other engineers at GM. Cooler cars run faster. 160 thermo's run cooler as observed.
it's all about knowing when to start the combustion process.
ever see an engine with tdc or after ignition timing?
I've seen taxi cabs in NYC with 300k+ miles on the odometer and they dont have thermostats or use Mobile one. I cant think of worse conditionas than that type of driving.
No condensation remains in a car running 20 degrees cooler than stock.
If you want to talk about wear and tear on suspension, bumpers, fenders, brakes, door latches and hinges.....that's another story.
I typed if you only go a several miles and the oil never gets warm. I do not know where you got the 220 degrees from ??? not me! Try running the car at 220 degrees (oil temp) for approximately five hours. Then check your oil pressure and check your oil. You will notice the pressure has dropped a bit and the oil smells burnt. So I am not a big fan of hot is better. The oil temp has to be not too cold and not too hot........ just like the three bears
Beating on a car that does not reach the proper oil temp will cause wear. My wife only drives a few miles to work and nails it as soon as she leaves the driveway
(I usually wait until the oil temp is aproximately 170 -180 degrees or what I consider operating temp) You should see what her rod bearings & etc look like when we took the motor out of the car
BTW
I have a 160 stat and it takes a bit longer for mine to reach operating temp (oil temp) ............... of course I drive mine like a little old lady
And for the pro lower temp guys.. my car pulls like a freight train now.. and all the time..
yup, some people just like to talk about their own theory and has no experience or data to back it up since they had never done it on a c6.
if they have hptuners software and can see how much timing is pull due to high ect & iat. they would be jumping ship in a second.
Only drawback im noticing is that it takes longer to get my oil nice and warm before my right foot hits the floor. I definitely feel the benefit of the lower coolant temps, which Im sure is due to the ECU not pulling timing from what used to be FREQUENT coolant temps over 200 and up to 230*.
