Mpg
Old Jun 26, 2007 | 03:44 PM
NewToC6's Avatar
NewToC6
Default Mpg
I was wandering what to expect for fuel consumption on my 06 a6 vert. I am only getting 12mpg. I have had it for awhile and dirve fairly conservatively. What should I expect for around town driving? Any Thoughts ??
Old Jun 26, 2007 | 04:03 PM
Buffy's Avatar
Buffy
That doesn't sound right; I get about 18 MPG around town. That's pretty similar to what I've heard from others on the forum.
Old Jun 26, 2007 | 04:10 PM
FloydSummerOf68's Avatar
FloydSummerOf68
If I do almost 100% cit driving I get 17.5mpg with the occasional spirited WOT accelerations.
If I do about 70/30 I get more like 20.5
12 is VERY low unless you are giving it a LOT of gas. When I first got my car I got about 12mpg on the first tank.
Old Jun 26, 2007 | 05:01 PM
Vette_DD's Avatar
Vette_DD
I'm getting about 17.5 mpg around town in my 06 A6 coupe. Not exactly stop-n-go traffic, but we do have traffic lights and/or stop signs about every 5-6 blocks.
After a limited amount of testing, I did discover that I get SLIGHTLY better gas mileage in "S" (without using the paddles) than in "D."
Old Jun 26, 2007 | 05:24 PM
Joezone914's Avatar
Joezone914
With my C6 z51 I was getting 14 all city (LA Traffic) driving. With the Z I now get 13. If i do a freeway trip Z51 was 25 the Z06 27 doing 75
Joe
Old Jun 26, 2007 | 05:30 PM
BLU-BY-U's Avatar
BLU-BY-U
thats really poor. my ls7 car would get at worse 15mpg (mainly city) and that was with major WOT blasts (my first set or rear emt's only lasted 4500 miles ). something does not sound right, try a different gas station and/or brand
Old Jun 26, 2007 | 07:34 PM
calemasters's Avatar
calemasters
Check it the old fashion way. Not by using the DIC. Then see where you're at.
I recommend checking it while on the highway. Too many parameters during city driving.
Old Jun 26, 2007 | 08:02 PM
SanDiegoBert's Avatar
SanDiegoBert
City driving will eat up the gas, but I'm getting 18-20 around town. I'm not a leadfoot, though. I could easily bring that down, trust me.
Old Jun 26, 2007 | 08:52 PM
old motorhead's Avatar
old motorhead
Default Whew...
You must have something bad wrong. With a car that lite and an engine that effecient, you can't stand on the throttle enough to go through that much fuel. Like others said, check MPG the old fashioned way. Reset the trip odo after refueling...at the next fill up, divide the miles traveled by gallons used. I've had several vettes and various other performance vehicles. The only thing that ate that much fuel was a big block powered 3/4 ton truck.
Old Jun 26, 2007 | 09:38 PM
m_LeDez's Avatar
m_LeDez
From: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
So your getting ~190 mile range per tank full?
Old Jun 27, 2007 | 06:18 PM
JGBeckwith's Avatar
JGBeckwith
Cruising
Default Fuel Mileage 06 A6 Coupe
Highway crusing (about 70 MPH) I get 35 MPG (A/C mostly ON). Average mileage over 2,000 miles with a good mix of city and highway and more than a few WOT "sessions" is 25 MPG. I'd think there is a problem with such low mileage as you quote.
Old Jun 27, 2007 | 09:07 PM
ModsByMarc's Avatar
ModsByMarc
Default in metric mode??
Are you sure this is MPG? Did you reset to Metric?
I have 6 spd manual, with headers, x-pipes, modified air intake... i get 18-19 in town, got 28.6 from Phx to SanDiego and Back.. almost all flat... air on.. avg about 85 mph.
On a totally flat run at 75 in 6th, i get instantaneous of 32-33 mpg
Old Jun 28, 2007 | 11:08 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Jun 28, 2007 | 11:11 AM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
05 MN6 Z51
Normally 16-17 City 27-29 Hwy
Worst I ever got was 14.5 city. But no hills and several 45 mph streatches.
Old Jun 28, 2007 | 06:16 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
06 Z-51 MN6: I get 22 for 50/50 freeway/city; about 19-20 City. freeway @80mph 26-28.
Old Jun 28, 2007 | 07:00 PM
BigL50's Avatar
BigL50
2007 Coupe 3LT A-6. At 75 mph, 2 adults with baggage, air on, we get 27-29 mpg. Around town, some freeway, some stop and go, we
routinely get better than 20 and I occasionally like to feel the acceleration capability of the car. We do have CAI and Borla cat backs.
I would check with my dealer. Low mileage is just not right unless you really hit it every time you are leaving a stop light.
Old Jun 28, 2007 | 07:19 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
You have a serious problem somewhere.
To Mpg
Old Jun 28, 2007 | 09:42 PM
mannyolivarez03's Avatar
mannyolivarez03
St. Jude Donor '08
Geesh...something cant be right, with AFR 205's and a G5X3 cam i still get about 13.5 per gallon city and almost 21 on the highway....Hope you get it figured out.
Old Jun 28, 2007 | 10:18 PM
xs650's Avatar
xs650
What is "around town" driving for you? If the traffic is heavy enough and you are spending a lot of time stopped and moving slowly the rest of the time, that would sink your mileage.
Are you using the paddles to hold it in lower gears, or letting it shift for itself?
Try driving at 5 or 6 mph and watching your instantaneous mileage on your DIC. It's an eye opener.
Old Jun 29, 2007 | 11:05 AM
ROD BROWN's Avatar
ROD BROWN
Default Not much better
12-16 around town.19-21 on the freeway.I don't romp it,but I don't drive like an ole foggy.
