Rear Problems?
Old Jul 6, 2007 | 05:21 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Rear Problems?
No not this rear, the 2005 MN6 Z51 rear?
I’ve heard that the 2005 C6 rears are the weak link in the drive train. The fix is to convert a C5 rear. Does anyone have experience with this problem?
Old Jul 6, 2007 | 07:16 PM
timd38's Avatar
timd38
Do a search, because I read someone doing it.
Old Jul 6, 2007 | 07:22 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
JT, you were just there man. CARTEK!
Old Jul 7, 2007 | 04:11 AM
SpinMonster's Avatar
SpinMonster
The center section of the C5 rear diff has more metal by virtue of the fact that it is where the mount attaches to the diff case. This is half the story; the C6 rear is supported by two arms that prevent the case from being able to rock left to right as the torque from the driveline twists. The pinion wants to walk up the ring and the two halves of the case are torn in a wishbone fasion. All the hardened internals in the world will not keep a weak case from cracking.
Fixes for the problem can be any or a combo of:
A side mount that absorbs the twisting motion.
A stronger case (material or thickness)
Additional metal at the fatigue points
A center mount that rocks back and forth
Old Jul 7, 2007 | 03:46 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Thanks guys
Old Jul 7, 2007 | 04:13 PM
Wayne O's Avatar
Wayne O
CF Senior Member
OK...I've been looking at this photo for a little while now and I still fail to see the problem....looks fine to me.
Old Jul 7, 2007 | 04:20 PM
beaversstonehaven's Avatar
beaversstonehaven
I've heard that too much TORQUE can lead to problems with this type of rear end.
Old Jul 9, 2007 | 12:50 PM
Dave_Busch's Avatar
Dave_Busch
I don't know about that, she may like a little more
Old Jul 10, 2007 | 04:58 AM
ZO6 Fan's Avatar
ZO6 Fan
Does the DTE Brace solve this problem for the C6 Diff Housing? I'm planning on purchasing one when I do my 410 Gear upgrade in Feb.........Thanks
Old Jul 10, 2007 | 11:28 AM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Don't know for sure but it's gotta help. I had CARTEK put the DTE brace on mine when they did my HD 4.10s
To Rear Problems?
