Would You Do This?
Old Jul 11, 2007 | 12:22 AM
Gman57's Avatar
Gman57
Default Would You Do This?
Would you open up a near new 2007 (1700 mi.) C6 and and install a mild/streetable cam? This car will have headers,ported TB/manifold and Vortex ram air installed befor the cam. Is the risk of voiding the warranty to great? Keep in mind the work would be done by the pro's in the shop and not DIY.
Looking for your input I have to get off dead center......Do IT or NOT
Old Jul 11, 2007 | 12:35 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Cam should almost for sure "void" some of the warranty,but if Your thinking about performance mods,don't worry about warranty!!{just do it!!}
Old Jul 14, 2007 | 09:14 AM
Gman57's Avatar
Gman57
Originally Posted by 1bdasvt
{just do it!!}
I'm taking the performance plunge............. Should have over 100 extra ponies at the wheels with these mods
Can't wait to see the boys at Straightline Performance at the end of the month!
The car
07, C6, A6, Z51, LMB, Vert
The build list
TEA Stage 2 Heads
LPE GT11 Cam
160 Deg. Stat
Ported LS2 Manifold & TB
BPP Vortex Ram Air
Kooks Headers & Cats
Corsa Sport Exhaust
Straightline Performance Tune
Old Jul 14, 2007 | 10:30 AM
johnodrake's Avatar
johnodrake
Moderator
The more I think about it the more convinced I am to return to LPE. I know of no other place for a 3 yr/36K warranty on a performance motor.
Old Jul 14, 2007 | 11:37 AM
Stinger !!'s Avatar
Stinger !!
My 2 cents...I looked into this exact thing with two 'un-related' local Chevy dealers...got basically the same answers...sort of went like this...
"If the modification has anything to do with or can be directly linked to a warranty repair issue, YES your warranty for that related repair will/could be compromised"
What this means is if you go in for an electric window warranty issue, the engine mods really have nothing to do with this, so it would be covered...if you have a tire sensor issue...probably covered...if you develop a noise in the rear end...probably will be related to added engine power...could be denied...and so on.
If you have any engine, transmission, drive train warranty issues, they would most likely be related and subsequently denied...
Worse part is these 'internal' types of engine mods is that repairs can be related to lots of issues due to having to tune and alter the computer...on a rainy day the service tech could tell his 'Boss' the car has computer mods and then potentially all bets are off!!
As much as I would love to tear into my engine, I decided to leave it alone...for now....it is to new ('07) to loose that 5-year 100,000 mile transferable GM warranty, as well as destroy any potentail future extended warranty availability...
Touchy choice here...good luck with it!
Old Jul 14, 2007 | 11:46 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Obviously, if you're concerned about your factory new car warranty....don't modify your car! You may have already lost vast portions of your warranty just with your other modifications.
I'm not oblivious to the financial realities but a built Lingenfelter engine is a great option. Besides the quality, power and performance LPE warrants their motor for 3 years/36,000 miles. You'll lose your factory 'drive train' coverage but it's nice to know that your engine has a warranty.
Gene Gorman's Avatar
Gene Gorman
What is a warranty? Just do it.
Old Jul 14, 2007 | 12:20 PM
SpinMonster's Avatar
SpinMonster
Warranties arent a tech topic but I modded my car the week I bought it. Mod it and post in the tech section what you did and the results.
Some car dealersd mod the car at their shop and it saves the warranty if they did the work. Check with your dealer.
Some mods are well hidden such as rear gears which should be the first mod anyway.
Old Jul 14, 2007 | 12:25 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Do it
Old Jul 14, 2007 | 01:12 PM
COALMINER,KY's Avatar
COALMINER,KY
I just took my 2006 mn6 in to the dealership for a leaking rear end. I have kooks headers, xpipe, vortex cai, route 66 exhaust, and a 180 stat. I just dropped it off and told them what was wrong with it. Then about 2 days later they called and said that they were replacing the axle. but said nothing about the mods. So i will continue to go to this dealership.
MOD FRIENDLY......
Old Jul 14, 2007 | 01:36 PM
SpinMonster
The car
The build list
TEA Stage 2 Heads
LPE GT11 Cam
160 Deg. Stat
BPP Vortex Ram Air
Corsa Sport Exhaust
Put the 1200 from the corsa into the Fast manifold.
Old Jul 14, 2007 | 02:43 PM
aTX427
Guest
Posts: n/a
There is a lot to your warranty. Installing the cam will probably void the engine warranty. If you blow a transmission or rear end, you will probably be on your own as well, however you are probably going to have to upgade them anyway to prevent breakage, so it is really a mood point.
Irregardless of what you do to the engine, it would not effect a warrany claim on non-powertrain issues, i.e., your stereo, or interior switches, etc.
Old Jul 14, 2007 | 02:45 PM
aTX427
Guest
Posts: n/a
I have a hard time justifying money for the axle systems.
To Would You Do This?
