Lowering info................
Old Aug 8, 2007 | 06:06 PM
bobburk's Avatar
bobburk
Default Lowering '05 Vette
I did, as I stated, have my Vette raised back and I don't scrape in my drive now. Alignment not necessary per Corvette West in Anaheim. They have a lowering kit for $40 but it is only 4 bolts with a large washer like head. Some say alignment needed if you raise or lower. Wheels do stop the hitting big dips but could also catch. Good luck.
Old Aug 8, 2007 | 07:04 PM
lowrag's Avatar
lowrag
3rd Gear
Had my 05 C6 rag lowered 1.5" last week. I have pics but I have to learn how to upload them. I replaced that stock bolts with WCC bolts. Looks sweet.
Old Aug 8, 2007 | 08:58 PM
dbratten's Avatar
dbratten
Originally Posted by haljensen
If that isn't enough; lowering shortens wheel travel, pre loads the sway bar which detracts from the designed handling characteristics and changes the factory corner weighting.
May I disagree.
Lowering per se doesn't shorten the wheel travel as you are not altering the spring only its contact point. Travel, however, may be limited by the car being low enough to bottom which stops further wheel movement.
The sway bar is not preloaded unless you dramatically lower one side and not the other. Dropping the car evenly simply moves the sway bar arms up as the bar rotates in its mounting.
Corner weighting shouldn't be affected unless you lower a corner an uneven amount from the height where your corner weighting was best. If when corner-weighting preload is placed on the sway bars adjustable endlinks are available to correct the problem.
--Dan
Old Aug 8, 2007 | 11:24 PM
journeyc6's Avatar
journeyc6
I agree with you:
-lowering does not shorten your wheel travel, is not like cuting or placing a smaller coils, thats when your wheel travel is shorter. the vette setup is different.
-no effect on the swaybar.
-lower to the ground, center of gravity is also lower to the ground, better handling.
-you will need an alingment.
-I can not even imagine raise my vette, thats insane buy a hummer if you need something tall
-I lowered mine 2 inches front and back, I only scrape the front air dam.
and drive careful. (no fat chicks)
Old Aug 8, 2007 | 11:27 PM
journeyc6's Avatar
journeyc6
I forgot: I had a C5 for almost 6 years lowered like my new C6 no problems from lowering till the day that I sold it.
Old Aug 9, 2007 | 09:54 AM
haljensen's Avatar
haljensen
Originally Posted by dbratten
May I disagree.
--Dan
1. Lowering does shorten wheel travel, read your statement above. wheel travel is xx inches, you lower by 1 inch the wheel travel (upwards only) is shortened by 1 inch (xx - 1 inch).
2. The sway bar is unloaded only at stock height, once you lower the car (raise the wheel in the wheel well) you are loading the sway bar. the sway bar end links are a fixed length determined at stock height.
3. Corner weighting is done by lowering or raising diagonal corners until you get as close as you can to 50/50 F to R. If you change the height of any corner you change the corner weights. I haven't seen any posts by guys with lowered cars that bothered to get adjustable end links. Most corner weighted cars have un-equal heights at the corners, they are corner weighted for handling, not appearance. Corner weight for handling, lower for looks.
Extreme case scenario; Base suspension car lowered to the max with Z51 rear sway bar and heavy aftermarket wheels/tires and no alignment or corner weighting =
1. Noticeable negative camber (and caster and toe changes).
2. Gross oversteer caused by the stiff rear sway bar and poor alignment.
3. Handling degraded by the unbalanced wheel/tire weight, poor alignment specs and uneven corner weights.
4. Extreme tire wear.
Believe it or not; Chevy has a reason for the different sway bar/ shock /wheel tire packages. They are PACKAGES, not individual parts just for looks. If you change one piece of the package you change the complete package.
Old Aug 9, 2007 | 10:24 AM
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
I don't think that's quite right. If you lower both front left and front right the exact same amount, the anti-sway bar preload will be whatever it was before you lowered.
Also, oversteer can be caused by the front anti-sway bar, not the rear.
-Ben
Old Aug 9, 2007 | 12:26 PM
Vet's Avatar
Vet
Lowering does shorten wheel travel...
I agree... in a lowered car, your travel will be limited... that is once the bottom of the car slams down on the road surface (due to a slight crest or other road imperfection). Forget suspension geometry, for street driving, your travel becomes limited by the road itself. In real world street conditions, you cannot expect the road surface to be dead flat all the time, that is totally unrealistic. Car can't go any lower once you pancake on the ground.
If there is any disagreement here, we need to then, from now on, simply denote whether we are talking about the realm of controlled professional racing conditions (track use), or show use (trailering the car to car shows), or actual street use... VERY different things.
Even the Nurburgring... which is a race track, though it does tend to emulate a typical country mountain backroad in some sections... in a few spots the suspension gets heavily compressed while on a bumpy tight curve... car also catches a bit of air in a few spots... imagine running a lowered C6 through there ... you'd never make it.
So again, before lowering, you must ask yourself the question, am I going to drive this car on the STREET, or am I going to merely trailer it to shows or race it only on a perfectly flat race track.
Just last night I was forced to go through a construction zone that had manhole covers sticking way up plus other serious dips and crests (it's a crime that they leave the road that way, but they do... that's reality). Then after getting through that, I nearly hit a bunch of tire bits (failed re-tread) on the highway, stuff that might have just made it under a slightly raised C6 but never would have passed under a lowered C6... I'm just calling it as I see and experience it.
Point is to merely be AWARE of the realistic dangers before lowering. You don't want to learn the hard way.
Old Aug 9, 2007 | 05:11 PM
dbratten's Avatar
dbratten
1. The wheel travel hasn't been altered. The fact that the car bottoms out doesn't mean that the wheel travel has hit its limit. Lowering the car to a point short of bottoming out will still give the full wheel travel -- unaffected by moving the leaf-spring contact bolt that this thread is about.
2. Sorry, but you're wrong. Move the F (or R) wheels up and down together and the swaybar has no effect and no preload. You can see this by unbolting your endlinks and rotating the bar in its mounts up and down. Static height doesn't matter. If the swaybar were keyed to remain in a fixed (rotational) location you would be correct.
3. I said it wouldn't be affected IF each corner were lowered the same amount. Most cars are not corner-weighted but those that are know to check the swaybars, too. Corner weighting often requires adjustable length endlinks to remove swaybar preload caused by having the wheels at difference heights. Non-corner-weighted cars do not need adjustable links (see #2.) Check over in the Autocross/Roadrace forum for further information. You'll also see that cars are lowered for handling as well as looks.
--Dan
Old Aug 9, 2007 | 07:07 PM
journeyc6's Avatar
journeyc6
lets get this clear: wheel travel won't be affected because:
-we are not changing the preload, height, or placement of the leaf spring.
-the leaf spring does not change position, the only part of the suspension that changes posistion (goes up) is the A arms, and thats beacuse the bolts are shorten, the distance betwen the leaf spring and the base of the botton A arm is closer now
-it may look like we have less wheel travel because the tire sits closer to the fender, but the reality is that the tire still travels normally inside the fender.
-youll get a uneven tire wear if you dont do an aligment.
Old Aug 10, 2007 | 10:34 AM
haljensen's Avatar
haljensen
Maybe the wheel travel misunderstanding is just terminology;
We have xx inches of wheel travel stock, 1/2 of the travel is compression, 1/2 the travel is extension. When you lower the car by 1 inch you shorten the upwards wheel travel (compression)by 1 inch, the wheel is 1 inch closer to the upper bump stop. Downward travel (extension)should remain the same.
Corner weighting;
Nobody has posted yet that they lowered the car for corner weighting, the posts are all about lowering the rear as much as they can without weighting the car. I agree that IF you accept that stock corner weighting is correct AND you lower each corner exactly the same amount AND change sway bar end links that the stock corner weighting won't change.
Rear sway bar;
Prove the load to yourself. With the car setting normally check the tension on the rear sway bar end links. then jack up the wheels OR jack up the frame of the car and check the tension on the end links again. Keep in mind that the sway bar load is supposed to be neutral at resting ride height. Any independent suspension needs neutral load at normal ride height for correct handing, when you change ride height you change sway bar load. Even Pep Boys sells different length end links!
My car was corner weighted (at stock ride height) at 53% F and 47% rear with me in the car and a 1/4 tank of gas. The guy that did the corner weighting said it was excellent for a factory car and that to change the corner weight would require a new alignment and possibly adjustable end links for the sway bars. Since my car is a street driver and the height was OK for me I passed on the corner weight changes and had an alignment done to the middle of the factory specs with no + or - allowances.
It's your personal choice, lower for appearance with out changing anything else, lower for handling with all the attendant changes required or leave the car at the stock ride height and the excellent stock handling. My personal choice (and the reasons for it) shouldn't change your reasons or your choice.
Old Aug 31, 2007 | 07:11 PM
dbratten's Avatar
dbratten
Rear sway bar;
All that you are feeling in the test you describe is the friction of the rubber mounts as they resist the rotation of the sway bar. To neutralize it all you need to do is loosen the mount bolts and let the bar find its new "normal" unloaded setting. Conduct your "test" with the mount bolts loose to see for yourself. Having the bar lubed will facilitate the rotation but in short time the bar will find its own "neutral" as you drive.
--Dan
