Z06 axle back
Old Aug 28, 2007 | 04:21 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
Default Z06 axle back
what needs to be done to install Z06 OEM mufflers .
does any one have any pictures of this set up?
how load is it with the butter flies open?
Old Aug 28, 2007 | 08:22 PM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Hi,
To do Z06 mufflers and not NPP's you will need a h or x pipe that goes from 2.5" to 3" to mate to the ls2 cats or install the ls7 exhaust manifolds and ls7 cats and z06 h pipe .
NPP mufflers bolt right in without a h pipe mod needed as they are 2.5" pipes.
You will need the vacuum lines and vacuum solenoid to open and close the valves and a controller to open and close them.
I did this mod and I am very happy with the results.
With the valves open on the freeway there is a LOT of drone. The overall loudness in the higher rpm range is not super loud, just throaty.
Quieter than bullets for sure.
PM me if you want any more info.
Old Aug 29, 2007 | 05:53 PM
aTX427
Guest
Posts: n/a
Is there a way to avoid using vacuum/solenoids/etc. and just hook up an on/off switch?
Old Aug 29, 2007 | 06:01 PM
oldasdirt78's Avatar
oldasdirt78
the borla system is what I went with, absolutely no regrets
I got it on sale Here
To Z06 axle back
