LS7 cam in an LS2
. But a daily driver is another story
. The LS7 cam will be quite and somewhat stealthy. Look forward to your thoughts.
It also feels like the car is getting quicker the more miles I put on. I have about 250 miles on the cam and every time I drive it it feels quicker.
How do the valve springs like all that lift as a DD?
Besides most intakes and heads really dont flow well above 600 lift, more like drop off significatly so there is no need to have that kind of valve lift.
Even with PP LS6 heads ( same heads for LS2 and LS3) a lift of 585 or max of 595 is more then sufficient to get maximum under the curve and top end HP.
cars are have lots of GO above 4000 rpms and not much under may be over cammed and would do better with a smaller cam. also cams with lots of go above 4000 tend to be slow off the line do to poor under the curve area or performance.
. Besides the differences in rocker arm ratios, are there any issues such as base circle differences or push rod lengths. Is it still streetable of an A6 car? I am looking for a bump in HP and quiet valve train for a daily driver, not the max HP. The work I will do myself. Looking forward to more input.The Best of Corvette for Corvette Enthusiasts
PP LS6 heads, TSP, TrickFlow, ETP 215 or AFR 205s or the like. For a cam that is a DD but still has some get up and gone
LG G5X1 228/232 588/574 112
Comp XE cca-54-444-11 224/230 581/588 114 2-7000 rpms
Mild
Comp 224/228 581/581 112 + 35 hp
TSP 231 231/237 595/595 112 1700-6500 rpm plus40-45hp
Most of these cams with AFR 205s or ETP 215s ( from what I have seen on LS6 engines) and the Comp cam may put you close to 500/475 RWHP/TQ with the right builder and tuner, the car would still be a good DD.
So many ppl want to put in cams with lifts in the mid 600s. But as I mentioned most heads dont flow well in the 600s or those the do are limited to the Intake runners. That combination give poor flow rates. Plus lifts in the 600s need constant spring monitoring. Where ppl should look IMHO is the flow rates at 200, 300 and 400 lift. Higher flow rates and these lower lifts give much more torque which means get up and off the line much faster.
For a DD reliability is very important.
I would really recommend to find a great engine builder / tuner who you can talk to and trust. Tell him what you want the car to do, and let them make a suggestion.
ETP Heads http://www.texas-speed.com/shop/item...d=617&catid=40
Hope that helps a bit.
One can look at Speed World Challenge LS2 engine, with PP LS 6 heads ( special LPE porting with almost un believable flow at 200 to 575) plus the cam of GM Cup cam 239/251 570/570 106 and these engines put out 550 bhp ( dry sump oiling)
ie the importance of a builder you trust. Talk to builders and let them know what you want your car to do?
One can look at LG speed world challenge LS2 engine, with PP LS 6 heads ( special LPE porting with almost un believable flow at 200 to 575) plus the cam of 239/251 570/570 106 and these engines put out 550 bhp
The cam you mention has alot of duration, narrow lobe center and moderate lift. It's a no brainer cam.
Plot the curve of a short duration cam w/lots of lift and you'll see that all that lift, while it isn't used on the bottom end, it does provide added duration at .2 and .3 lift. Which is where we want lots of flow, all things being equal.
Fortunately, the LS series intake/heads can and do provide good airflow and provide little restriction at these lifts.
It drives out very nicely and a lot of fun. A little loss on the low end but the 4.10's make up for it. It's not a DD, just a toy.
Not trying to hijack your thread.
I question DD with lift short duration at lift @ .6 and up.
To the OP, I found the LS7 cam is 211/230 on a 110 w/.593/.588
I haven't found what the intake centerline is, anybody know?
...sometimes in our desire to help others we never answer their question...there is a lot of excellent/helpful advice in most persons' responses but if anyone can answer the original question put forward
GM LS7 Cams
LS7 stock 211/230 591/591 120
GM LS7 Hot cams ( release TBD)
230/231 593/588 120
227/239 583/583 116
233/276 630/630 116
LS7s run with 1.8 Rocker, not the 1.7 rocker that LS1,2,6 and 3 run
Where did you get your specs? I found the cam timing events to come up w/mine.
