When should I shift so that I get max RPM without red lining? I really cant tell. It looks like there is a couple of second delay from the time you hit the up shift paddle til the time the transmission actually shifts.
I was thinking maybe 5000RPM??
Is it worth using the paddle shifter or will "D"rive actually give you the same performance?
Just like a stick you don't shift at the red line but about 500 rpm before it. However, for the best performance leave it in "S". It'll start in 1st (Drive starts in 2nd) and the computer will shift faster & at the right time every time faster than you will.
I had no idea that "D" starts in 2nd gear? So, when running the car in the 8th or 1/4 its best to paddle shift so you can start out of 1st vs 2nd (when in D)? Thats weird, my best times were when I just left it in "D" - Paddle shifting has that damn delay and its hard to time it. It seems as if it stalls before a shift.
I only use the paddles for downshifting. Up to D and then back to S for upshifting. I have a habit of forgetting to upshift. (sarcasm on) This is unless I am on a twisty road, which everybody in south Florida knows there are lots of (sarcasm now off).
Any suggestions?
Unfortunately it's too late to suggest the manual 6-speed....that sounds horrible. With a couple second delay I'd also question whether it's worth using (or buying in the first place). Personal comments aside.......
I'm guessing there is no set answer (or set pre-red line shift points) as conditions and demands on the car vary. I would think with practice you'll get a feel for how to best compensate for the shift-lag. Perhaps the lag can be reduced through tuning?
If you are drag racing, the only way to go is D or S... not paddles. The transmission shifts faster than you can. There was a thread about this some time ago that included timing from GM engineering on the difference. I use the paddles for fun and around town, but if I was running down the track, I would stick with D or S.
Note: I have been told by a GM tranny tech that there is no difference in the shift algorithims between D or S. The S only tells the it that you want to use the paddles. It doesn't change the way it shifts.
As for 1st gear, my '07 goes to 1st in Drive mode everytime.
Other than my IS 350 (Which don't offer manual transmission) This is my first Auto so I really wasn't sure how to drive it to get the best performance. Thanks for all the Advice. Looks like from what you all are saying is the paddles are more for fun than actual performance.
Each gear is differnt and varries due to your thumb speed and traction as well
I have made many runs in S auto and Paddle mode my et's mph and shift times are better in Paddle mode From the data I have collected the shifts are shorter in paddle mode, I use HP tuners and am comparing how long it pulls timing on the shifts.
I would shoot for:
1-2 6,000-6,200
2-3 6,300-6,400
Best to look at your log file to see where it shifted if you dont have a scanner try to see where it shifts but in my exp it shifts ~100 later then my eye sees
When you use drive...lt should start in first. When you use s mode it also starts in first unless you touched the paddles. If you haven't touched the paddles it shifts just like drive mode. When racing, the s mode feels like it has firmer shifts. USING THE PADDLES FOR DRAG RACING IS ACTUALLY LESS EFFECEINT THEN THE AUTOMATIC S MODE.
I downloaded the Predator Performance tune into my A6 and it appears to me to have shorten the delay with the paddle shifters. I can tell you for sure there is not a 2-sec delay. Has anyone else experienced this? Since I didn't use the paddle shifters that much before I uploaded the tune, I can't give a good comparison.
I have an 07 A6 Z51 3LT and in S with the paddles activated it starts in 2nd. I have to paddle down to first manually to start in 1st. It will downshift itself until I stop, down to 2nd but will not go into 1st unless I paddle it down to first.
It probably starts in 2nd because the 1st gear in the A6 is so low.
But without the paddles activated, it goes to 1st in D or S.
Any suggestions?
I have an 08 and don't find a delay like what you said, shifts are right after I push the paddle forward, but I have hit the reve limit already, so I have had success with shifting about 700 before redline.
The Predator tune has made the shifts firmer and faster. could be my imagination but the car runs so much better that is sure to have a positive effect on the tranny. I have experience using the paddles before and after a tune. The predator works great!
Do you have any data to support that claim?
I will have to do some digging... but about a month or so ago, someone had their hands on powerpoint slides from a GM engineering presentation. It listed the time in ms for shifts in various configs and the presenter said something to the effect of "the full auto mode will shift faster than the driver can". Seemed legit at the time.
For my part, I don't think the shift engage times are any different, but shift points are hit easier when in full auto. But I'm still a 99% paddle shifter!
