Do Octane Additives Really Work ?
Old Oct 24, 2007 | 08:24 PM
  #101
siffert's Avatar
siffert
I was saving this last case for myself for a backup, but I'll ship it to you on Monday, you'll see it in a day or two! I was about to put in another order from Torco anyway...
Are you the same guy that did that C6 highway video with Jenny P holding her implants and a bottle of Torco??
If so, even if Torco is , your OK in my book!!
Does Jenny really have all those tatoos on her back? , mind you, not complaining about the front!
Old Oct 24, 2007 | 08:38 PM
  #102
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
I don't question the fact that Torco raises octane. What I question, is the benefit of increasing the octane of the fuel in your STOCK Corvette, increasing the spark advance, and then expecting more HP?
The purpose of timing advance is to allow enough time for the flame front to travel across the combution chamber, fully ignite the air fuel mixture, and begin exerting a downward force on the piston, just as the crankshaft passes TDC. The faster the engine is turning, the more of a head start the spark needs. Hence, more spark advance as a function of engine speed. So, at a given RPM, there should be an optimum point WRT to TDC, at which the spark is delivered, correct?
So how could a STOCK motor benefit from firing the spark plug sooner, and subsequently increasing the octane level (knock resistance) of the fuel (i.e. - the Torco tune) And if someone proposes it's because the Torco tune is leaner, it's already been stated that the LS3 doesn't seem to benefit from leaning ?
I do see the benefits of increasing the octane level of the fuel in motors that have forced induction or higher than stock CR, or if you can't get the proper fuel for your engine locally. Otherwise, for a stock motor, I don't see that much benefit.
Old Oct 24, 2007 | 08:39 PM
  #103
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
Originally Posted by LSCHLEM
After all the threads ive seen here it appears that TORCO is
a viable product that can increase performance. I have a problem
with those many products out there with claims that are very
misleading. Like c6 dvl who put 3 bottles of LUCAS in her tank and found it to be total crap. We need more auto owners to post here and everywhere to expose their phony or misleading claims. Some of that
stuff should never make it to the shelf.
shhhhhh, my wife don't know! it was supose to be our secret
All I know that Lucas crap (maybe excessive of me puting 3 bottles in the tank) slowed me down!, and I was told putting that crap WITHOUT tuning for higher octane is a waste.... I was also told to have a can of Torco on hand when I'm ready to tune
somebody shoot me
Old Oct 24, 2007 | 09:17 PM
  #104
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
C6 Dvl , Sorry I Was A Little Confused.
Old Oct 25, 2007 | 03:10 AM
  #105
magls2's Avatar
magls2
Default Try Liquid Horse Power the Stuff really works !!!
This stuff is available at Service Center in Lomita, California. Talk to the folks over there. (Call directory assistance)
I have been using the stuff since the mid 80's on my 13:1 compression 455 using 91-92 pump gas without Knocks and runnubg advanced timing
The Stuff is Cheap, non-combustable and can be stored for a long time
