Do Octane Additives Really Work ?
Old Oct 6, 2007 | 11:08 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Do Octane Boosters Really Work ?
Yesterday i purchased a bottle of "LUCAS OCTANE BOOST".
After reading the label it indicated up to 25 gal w 1 15oz bottle.
After searching i found out that there is no practical way to
boost octane say from 93 to 96 on a full tank of gas in a c6 corvette.
It simply indicates pour 1 bottle into a tank of gas. Thats kind of vague for me.
Any of you guys have any experience with this? would appreciate any comments on this.
Old Oct 7, 2007 | 12:54 AM
huckleberrydude's Avatar
huckleberrydude
you are waisting your $$$$$
Old Oct 7, 2007 | 01:00 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I've been using Torco for over 5 years, and have tested it on the dyno, track, road, and lab! It kills knock retard, and allows you to run more timing, which in turn lets you make more HP!!
I just got off the dyno a few hours ago with my new 08 C6 Z51. I mixed in just over a can per tank, and, well lets just say I'm Z06 hunting!!! A bone stock one anyway...
Torco/tune/VR/Headers/exhaust:
I'll post up #s soon...
Old Oct 7, 2007 | 01:06 AM
huckleberrydude
Good luck too you.
Have found very little from fuel additives and you could add the cost of what you spend on them for a year or two and buy some HP.
Old Oct 7, 2007 | 01:31 AM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Good luck too you.
Please check sig, I've bought plenty of HP!!!
Old Oct 7, 2007 | 08:58 AM
LSCHLEM's Avatar
LSCHLEM
The lucas product is really octane booster not just something to clean
injectors etc. Is there any one who tried this with results. Its like $9.00 a 15 oz bottle.
Old Oct 7, 2007 | 11:20 AM
haljensen's Avatar
haljensen
Ask jbsblownC5 about Torco, he knows that it works. The Torco Unleaded will bring 10 gallons of 93 Oct. to 104 Oct. with one 32 oz. can. I used it for thousands of miles it my SRT4 with no ill effects.
Old Oct 7, 2007 | 11:44 AM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
This is what the can says, and I too have used it for over 5 years in my car as well with no down side!!
I had some lab tests done, and the results with 91 octane were:
10 gallons of 91 mixed with one quart of Torco is 96.5 octane!!
JB
Old Oct 7, 2007 | 02:19 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
No offense but - you think an '08 with LT's, a vararam, a tune and some Torco will beat a Z06 ?
Old Oct 7, 2007 | 03:13 PM
RAMAIR's Avatar
RAMAIR
I don't think he ever said beat. From what I have seen the LS3 with the mods list above is very close in HP as the LS7 on the dyno. Some don't want to believe but whatever.
Old Oct 7, 2007 | 03:15 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
As far as HP, my 08 is right there with a BONE stock Z06. My Tq seems a bit higher in some cases. It would come down to driver. Now most Z06 owners might have a problem with this, but it's all for fun anyway!! Yes the Z06 is lighter, but my car has more TQ. I'm pretty sure the tranny and diff are the same as well...
No offense taken, but if he did edge me out for some reason, I'd just line back up with the 98 and say BYE BYE!!!
Old Oct 7, 2007 | 03:46 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
That's assuming I believe the dyno numbers. And yes, that's what he implied by saying he was looking for Z06's. I don't think it was hunting Z06's so he could admire the wide body. BTW, take a look at what I own. I'd love to believe his car could beat a Z06 w/ those mods, but I don't.
No offense taken,
Glad to hear it. I'd love to see you line up against a C6Z06 at the track.
Now that wouldn't really prove much except that you own 2 very nice cars.
Old Oct 7, 2007 | 03:59 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
So you are saying you don't believe the dyno, or you don't believe that if two equal drivers lined up the one with more power would win???
Old Oct 7, 2007 | 04:21 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
I'm saying I suspect that the dyno you used is "generous". I don't think that with the mods you have, with equal drivers, your car will beat a stock C6 Z06 in the 1/4 mile.
More specifically, I think the gains to be had from something in a can are minimal on a stock motor.
Old Oct 7, 2007 | 04:47 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
It's my dyno and it is accurate. This car dyno'd 376 stock...that's totally in line with published factory specs and lower than many others reported on this forum.
The mods are a great combination that were chosen to take full advantage of an LS3 and they do just that.
Last, Torco is indeed a viable octane booster used by thousands to enhance octane and fight detonation. In California, where 91 octane reigns, one can of Torco will bring us up to 94....that's 30 points.
Old Oct 7, 2007 | 04:59 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
I'd put money on the Z06 with equal drivers any day of the week. First off more rubber to the ground for traction. Id also love to see back to back dyno's of a Z06 against this car on the same day, same conditions, same settings. The z06 is going to spank you.
Old Oct 7, 2007 | 05:27 PM
Thrill6's Avatar
Thrill6
Higher octane does not translate into more power. A car is tuned to run on a specific octane rating. Using a lower octane gas means less power, but higher octane does nothing.
The tune sets when the spark plug fires before TDC, the closer to TDC the spark fires, the more power you get. Higher octane gas allows you to set the spark closer to TDC. The engine does not have a fuel analyzer to figure out the octane of the gas, so it can't move the spark advance forward. The engine can detect when you have gas that has a lower octane rating than it is tuned for via the knock sensor. Knock happens when the fuel spontaneously combusts (due to pressure and heat) BEFORE the spark plug fires. The engine detects the knock and fires the spark plug sooner, resulting in less power. The higher the octane the less likely it will spontaneously combust. Using fuel additives to raise the octane is a waste unless you have tuned the car to use that higher octane gas.
To Do Octane Additives Really Work ?
Old Oct 7, 2007 | 06:43 PM
keyplyr's Avatar
keyplyr
Nicely said
Old Oct 7, 2007 | 07:44 PM
LSCHLEM's Avatar
LSCHLEM
If one would boost the octane say from 93 to 96 and put about 2 degrees of advance on the tune are you saying there would be no hp boost increase ???
Old Oct 7, 2007 | 08:37 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
As stated a few times already, I had the car tuned with the specific amount of Torco/91 mix that I will run every time. We were then able to add more timing, and the car is able to be tuned to a more aggresive level, hence the sprite #s!!!
I will say this, from my direct experience and what I have SEEN first hand, A stock tune or a modified tune will be fine under normal or semi normal driving conditions. If one is REALLY into driving their car, roadcourses on Hot days, or hard mountain cruises on hot days, then the intial tune may not quite cut it. The computer will pull timing as it senses KR, and you will loose HP.
I agree, under normal condition, without the car being tuned for it, running Torco or mixing in 100 octane is of no value, and will not get you any more power.
JB
